Lori L
    Female
    876
Lori L's Achievements
Apprentice (3/14)
5
  1. Thank you. I have a 2021 Hull number 876. I will add that to my profile. Thank you! There is no cell service here so I had to come to an area with Wifi. I will go back and take a look at that. Thank you for the suggestion!
  2. Hello. Just a quick question for anybody. I am camping at Cades Cove in Tennessee. There are no hookups here. My freshwater tank is full and I am in the normal valve configuration. I turned the pump on to pressurize the system and there is a faint clicking noise, but doesn’t sound like it usually does. There is a slight flow of water when I turn on a faucet, but definitely a lot less than usual.I have checked the breakers and fuses. I thought maybe I need to manually prime the pump but of course I don’t think I have the right tools to do that. Any suggestions. Thank you so much!
  3. Thank you, jd1923, I appreciate the additional input and will definitely be following through. I’m just relieved I didn’t mess something up.😀
  4. Thank you both! Great information. I am at a full service site now so both tanks will get a good cleaning. I appreciate your responses.
  5. I added a valve in the bumper so I could keep my drain hoses connected and not have anything leak into the bumper area when done emptying. Well, I forgot I did that. And did not open the valve in the bumper. And when I went to empty my black tank first it went from 50% to 10% full. Then I went to empty my gray tank and noticed it wasn’t emptying. That’s when I realized my mistake in not opening the valve in the bumper. So I shut both valves, opened the valve in the bumper, then opened the black drain valve. The black tank went down to 5%. Then I shut the black tank valve and opened the gray tank valve and it worked as it should and went down to about 40%. What I am afraid of now is that my black water backed up into my gray water tank when I had the valve in the bumper closed. Hopefully I explained this well enough. Does anybody have any thoughts?
  6. Was following the video to winterize my Elite II. Followed all the steps, drained water tanks, turned off the gas, turned off water heater, adjusted by-pass valve, set the ball valves for winterization mode, cleared water out of faucets, everything up to attaching the hose to the inlet to pull in the antifreeze. I turned on the water pump and turned on the cold water in the kitchen sink. The hose pulled some of the antifreeze out of the container then no more movement. Some water was spurting out of the faucet but that was it. I finally turned off the pump because I didn't want to ruin it. Not sure what I am doing wrong but I am sure it was something I overlooked. How should the ball valve be oriented on the fresh water tank? Does it have anything to do with winterizing? Should there be a water source? I feel dumb for asking, it seemed pretty simple on the video. Any help is appreciated. Last thing, after winterizing I was planning on leaving the camper plugged. Should I turn off the inverter. I am planning on leaving the batteries (lithium) in the compartment in the camper and not doing anything with them. I live in North Alabama, temps dip to 19 or 20 degrees some nights. My camper is stored in a garage. Just adding that info in case it is helpful. Thanks for any assistance--Happy New Year!
  7. Hello,
    I know this is posted somewhere but can you remind me how to post the US Map as part of the signature. I saw the post some time ago and can't find it again.  😀
    Thank you,
    Lori
    1. Mike and Carol
      Mike and Carol
      Hi Lori, here’s a link to the instructions that I use.  Let me know if it works for you!  Mike
      https://olivertraveltrailers.com/forums/topic/2567-how-to-add-forums-signature-maps/
    2. topgun2
      topgun2
      Lori L -
      A quick use of the Forum's Search function gets the following:
      https://olivertraveltrailers.com/forums/topic/2567-how-to-add-forums-signature-maps/?tab=comments#comment-23893
      Good luck,
  8. Thanks to everyone. I really appreciate you all taking the time to help me! I have pushed the power button on the wall unit in the cabin and the power button on the inverter itself. I am going to plug something into the inverter itself to check that. Although I don’t have high hopes for that as there has been nothing on the display screen on the inverter. I will also check the voltage when I get back to my campsite. I hope you all are having a nice weekend!
  9. Inverter still not working. I have pushed the power button on the inverter, flipped the breaker, reset the GCFI plug, and the lithium batteries are charged to over 80%. I will look for the inline breaker as well. Also what should the battery voltage threshold be? Thank you for all the feedback!! Had the camper less than two months. I guess I will call service department tomorrow.
  10. Hello. I have been researching the forum and I am sorry to ask a probably not so smart question and one that’s been answered but I have no power to my outlets. I have the inverter and solar package and I am not plugged into shore power. I have no Internet at my site so I was hoping to get a quick answer for troubleshooting so that I can fix it when I get back to the campsite. This is our first time boondocking so I am sure I am missing a simple step that was already explained in the delivery walk-through, but….Any answers or links to previous posts or info would be appreciated.
  11. Thanks so much for the reply. I appreciate the assistance and the link regarding the longer hoses. Take care!
  12. Hello. We just took delivery of our Elite II and are experiencing the same short cycling issue. Sometimes with as little as 2 minutes between cycles. I was wondering if you were able to resolve the issue and how? Thanks!!
  13. Hello, I have seen some threads on this general topic but am still a bit confused-sorry if I missed a topic that addresses this. I wondered if anyone uses the camp chef explorer 2x stove and if the propane hose pictured below works with it and the QC system for propane. Even if you don't use it but can provide any feedback that would be great. Getting my Oliver on Friday (VERY EXCITED!!) and want to have all the right equipment. I get the hose pictured on Thursday. I know--nothing like waiting until the last minute--not sure why I thought getting this would be simple. 🙂 Thanks for your time!
  14. Hello, I have a the two burner Explorer from Camp Chef. I bought the propane hose that you have pictured. Do you have to modify the flare fitting on the end to fit the camp chef? When looking at the grill, it seems like the hose with the regulator is permanently attached. Did you have an issue getting that hose off and attaching the hose that will connect to the quick connects on the camper? Getting my Oliver on Friday and I am trying to have everything ready to go. 🙂 Thanks!
  15. AndrewK and SeaDawg--thank you for the pictures. I think black will work the best with my truck color. JRK--I would appreciate hearing what you think about the Lithium Pro vs. Solar Pro packages. I think I will do one of these instead of piecing together options. Your comment about the AGM batteries definitely makes sense. Thank you!
