Zodd
Zodd last won the day on May 27 2025
Zodd had the most liked content!
    1305
    2023
Zodd's Achievements
Community Regular
Community Regular (8/14)
297
  1. What microwave do you have that allows it to run on batteries? I have never managed to get mine to work without tripping the inverter. I own the Hightouch Convection Microwave.
  2. hehe, well now @jd1923 you are just trying to make me sound really lazy šŸ˜‰ The absence of a cord is really convenient, but when I need to wake up at 5 AM for a work call, I try to be quiet so I don’t disturb my wife. This becomes challenging when I have to open and close the door. So far, I've been using the AC adapter and turning the inverter on and off as needed. I'm considering options that don't require the inverter to be operational, so I can keep it running continuously. Still trying to weigh cost/effort/reward. So far using AC adapter has been fine and I have never been short on power.
  3. I like the idea but it has a couple challenges for me. 1- Most of those do not have a low power shutoff. So if you forget to unplug it you may kill your battery. A direct connection to the TT batteries avoid this. 2- This leads to the challenge of having to go outside to turn it off. Not so fun when warm inside and ready for bed and you remember it is still on. 3- Even with low power shutoff if you have to wake up early in the morning to get some work done you have to jump outside and switch the battery out. I am leaning more toward something like this. About the same cost but still has cables and some manual labor to get wired in. A little lower cost and a little less setup with no need to switch inverter on and off. https://a.co/d/03RI49lb
  4. Ah nice. Thanks for the clarification. I missed that part.
  5. It depends on your plan. Starlink recently changed its roaming plans, now you can't use it while in motion. I love Starlink, but when will their plans stabilize? They still change them every six months.
  6. We have never used the remote. The Oliver is not that big, and it feels like more work to get the remote and point it in the right direction than just stand up, take 1-2 steps, and use the panel.
  7. Nice! If you are an AI fan (trust but verify šŸ™‚ ) you can use AI to search and summarize for you as well.
  8. For those that don’t want or know how to set this up locally You can also do a google search of just the forms natively with google by starting your search with the forum URL like this. ā€œhttps://olivertraveltrailers.com/forums tire pressureā€
  9. We live in North Idaho, where we experience snow and ice. We use a Clamark cover for our Oliver, and it has been excellent. Our Oliver is parked on the side of the house next to the garage and fence, so it doesn't get much direct wind. To protect against any potential damage, we place padding on the sharp corners, such as the bumper and solar panels, ensuring that nothing gets scuffed. I haven't noticed any signs of the fiberglass being scratched since we have a ceramic coating. If it were exposed to more wind, however, that could be a concern. Putting the cover on can be a challenge, but we've developed a great system that makes it relatively easy. When we take the cover off, we roll it up so that it fits in a plastic tote. We roll it in a way that allows us to simply lift it out at the end of the season and place it on top of the Oliver. Then we roll it forward and let it drop off the sides. This method is much easier than the first time we rolled it on on the ground and tried to lift it up and over.
  10. First, I had never heard of snow socks. I did some research that you may find interesting as well. They seems like pretty good options. Compare different types
  11. Thanks for the additional info @Steve and MA
  12. We are not in the market yet, and it would be a drive for sure, but the idea of a "permanent coating" from Master Applied Coatings sure is an interesting story. Spending this money once versus every handful of years would be great.
  13. It appears that you have already asked this question and received some responses.
  14. Rather or not you are plugged in is the primary question. See their manual. https://cdn2.olivertraveltrailers.com/wp-content/uploads/2024/05/30122505/Lithionics-Batteries-Storage-Procedure.pdf ā€œ1. If your battery has the Lithionics Internal Heater, and you are subject to winter conditions, keep the battery ON, solar ON and plugged into shore power. Shut down all appliances, lights, and other DC loads. You may purchase a very small charger from Lithionics Battery (KF Series) and power this from an extension cord if shore power is not available. This will keep the heater running and protect your battery. Doing this will eliminate the procedures below.ā€
  15. We went with a ā€œcheaperā€ brand. We have had it a year and so far are very happy with it. I would at least say cheaper is better than nothing at all in the case of a TPMS.
