aaronorange
    Idaho
    1238
    2022
1,872 profile views
aaronorange's Achievements
Enthusiast
Enthusiast (6/14)
62
  1. That’s the same Optifuse breaker Oliver sent after I first reported the problem. Could I possibly have gotten 2 bad breakers? Back to the drawing board…
  2. Thanks, what exactly did you get as a replacement? I will order a couple. Thanks again
  3. My 300 amp optifuse keeps tripping when I try to run the Truma AC. It’s pulling around 800-1100 w when the a/c compressor runs. The fuse randomly but often trips. This is the replacement fuse/breaker from Oliver. They sent me a new fuse right after we bought it for the same issue. I was at Oliver last fall getting the Truma a/c installed and asked them about the constant Error 20 code but they had no idea. So this year I’m not getting the error code just the 300 amp Optifuse keeps tripping. And it is very hot when I reach down to reset. Tripped again today (5/21). Everything looks good and tight.
  4. Mine also came loose, on my way to pick up some 3M VHB 4950 or the redialy avalible Gorilla DST
  5. I see the Blue Seas is a 100 Amp fuse while the original Optifuse is 300 did you use this exact fuse? I'm going to try this one as well. Thanks!
  6. I’m on my 2nd OptiFuse breaker. It trips often. Not sure what to do but I would like to replace it with something better.
  7. Speedy RV charged me $50. David said it was half of his hourly charge. I was just happy to get things squared away and ready for travel. Our unit (1238) is a 22, so it was new looking as well.
  8. New burner installed yesterday 4/24/25 by David of Speedy RV in Benson AZ. Thanks for all the input!
  9. Has anyone received a replacement burner from the Truma water heater recall? It's been nothing but crickets on my end from Oliver. I have emails and calls to Oliver but have received no response yet. I haven't used my water heater for months, and need to know if it is safe to use. I suspect they may have been closed due to all the recent storms. Hopefully, everyone is okay.
  10. Anyone know if Oliver got the replacement parts? I was told in January they were 60 days out. Was anyone told not to use the water heater?
  11. Mine never fully seats. Our first dump was quite a surprise. The hose was completely full from the valve not seating completely. I now manually close it at the valve under the galley seat. I also keep a gate valve on the end of the hose. It seems to me the cable is to short, I have it fully adjusted. I do have a replacement cable but just not sure how to run it through the maze of obstacles. Has anyone replaced the cable?
  12. Just wondering if you travel with the water tank full? I figured that’s what it’s made for. But I hear some people don’t top off before heading out.
  13. Congratulations! It's a beautiful-looking setup.
  14. I prefer fiberglass 😀
