Coddiwomple
Location
North Plains, Oregon
1382
2023
Legacy Elite
4,874 profile views
Coddiwomple's Achievements
Coddiwomple started following HOW TO: Isotherm Intelligent Control for Cruise 130 Refrigerator , Bulldog shocks installed , Cracked bushings on Monroe Struts and 7 others
Coddiwomple "to travel in a purposeful manner towards an unknown destination"
Might work but wondering if the L bracket will move when drilling and attaching screws. All is good so far.
Going back to Geoff's original post on this thread, I did this (except for relay) and it works great but have been concerned about water penetration at the exterior socket when Starlink cable is plugged in. I have swapped mine out for a water-resistant component custom designed and made by Tom at Platypus3DDesigns in Mesa, AZ. Although the original socket worked great, it was not water-resistant so I asked Tom to create one that would replace the Furrion Mini TV/Satellite Inlet. Here is the link to his component. https://www.etsy.com/listing/4349330543/starlink-mini-dc-cable-pass-through It has 18 gauge wires attached and a magnet that holds the cap in. In addition, he adds another magnet on the side that can hold the cap when not inserted. I asked for a modification so I could add a lanyard. Tom drilled and threaded #8x32 holes for that. All screws and machine bolts were attached with blue Loctite. I was able to use the original Furrion gasket. I had to drill out the hole in the fiberglass a bit larger and I wrapped some butyl sealant around the barrel upon installation. Here is a link to the lanyards. https://www.amazon.com/dp/B0B4RXTKBH?ref=ppx_yo2ov_dt_b_fed_asin_title&th=1 To finish it off, I used a very small amount of dielectric grease on the cap seal and rubber fins on the Starlink cable end. Works great. David P.
More DC to DC charger installation tidbits
Coddiwomple replied to Snackchaser's topic in Ollie Modifications
Hey Carl, you can come over to see how I did mine in our Elite 1 if you like. I don't know if you remember me and Martha but you showed your Elite 1 to us on 9-3-22 when we were considering an Oliver. We are in North Plains. -
Elite I bed across the back and adding some color
Coddiwomple replied to Ron and Phyllis's topic in Ollie Modifications
I don't think it was a custom top. I just told Oliver folks that I wanted a smaller Lagun-type table top and they said they had one available at the factory. I don't know if they still make them. We are very happy with our setup and it works great for us. Cannot think of anything I would do differently at this point except if you have a table top made you will want it to be as light as possible. We always remove ours when traveling. David P. -
Seek Blu Technology Hose Quick Release Fitting Cover
Coddiwomple replied to Gliddenwoods's topic in General Discussion
We have Eley quick connects and contacted them directly. They recommended some covers (along with part numbers) from McMaster-Carr that fit perfectly for both male and female parts. Only problem is that you have to buy a bag full of them. So, you might try contacting Blu T support. With all that said, what works really well for us now is a 2" wide roll of blue painters tape to cover the outlets when traveling to protect from road grime. -
Thank you Geoff. Correct. They did say it is OK to connect and disconnect at the Anderson plug with the engine running, however, they felt it was a "good practice" to have the engine off. Thanks for clarifying that.
I actually asked Artek these same questions and was told that a switch is not needed. Additionally, they said connecting and disconnecting should be done (as a good practice) when the engine is off and no charge current coming from alternator.
I used the following that were recommended by Artek. 1. Blue Seas MRBF Terminal Fuse Block and a MRBF 60 amp Fuse. 2. Blue Seas Series 187 Surface Mount Thermal Circuit Breaker 60 amp. I have attached photos.
No, I did not work with Oliver on this project. -
Thanks Ron. Haven't tried that but will consider going forward. -
I’ve attached photos showing how I mounted the EZ Reach table system. To do this, I used a 12" x 16" aluminum sheet and aluminum L brackets. Additionally, I attached an angled brace from the top of one of the L brackets to the aluminum frame supporting the heater. The setup is very sturdy, and we’re pleased with how it turned out. For the EZ Reach system, we selected a 16" arm and a 12" arm to achieve the level of articulation we needed. The table top was purchased from Oliver. Note: We always remove the table top from the system while traveling. Hope this information is helpful! -
LE1 Generator Selection
Coddiwomple replied to My Imagination's topic in Mechanical & Technical Tips
You do not need this relatively expensive kit, with regulator, if attaching the generator directly to the Oliver onboard LP quick disconnect which supplies regulated LP pressure. Yes with an external tank, but connected to the Oliver only a hose with correct fittings is needed. I just spoke to Derek at Hutch Mountain and he asked me to post this to clear up a misunderstanding. When installing their propane conversion kit, it is required that the large Demand Regulator is still used when connecting to the onboard LP quick disconnect.
