shhQuiet
Everything posted by shhQuiet
  1. You speak the truth. The reason I went with this was primarily because I already had most of the gear lying around not being used and also because I am a technology guy and enjoy it. But I'm not poring over graphs when I'm out camping! This is part fun / part diagnostic tool.
  2. Ohh you’ve got an evil mind! 😈
  3. This is the travel router I got: https://www.amazon.com/dp/B0BPSGJN7T
  4. Another really game-changing aspect is the Oliver's local network. I had never heard of a "travel router" before, but they are very small wifi routers that connect and are powered by USB. The way they work is you have all your devices connected to the travel router's wifi always. When you travel, you can use the travel router to connect to different things, like a campground WiFi, or Starlink or whatever. That way, you don't have to reconnect all your devices. Plus it provides a layer of security over just using a public wifi. Along with that, I use a service called Tailscale, which is really great. It allows your devices to join a private VPN and they can communicate over the public internet. That's how I can connect my phone from anywhere to the Oliver. Tailscale is free with a limit of 100 devices. I think I have 7- like mac, iphone, ipad, oliver, a few others. I know it's a lot of information if you're not interested, but I am tickled with how it works and how much it costs, other than the doodads I bought to get it all hooked up. No monthly service fees!
  5. Well, thanks so much! I actually started thinking about a display and I wanted e-ink, but got hung up on the mounting and the powering (plus the $) so I just went with the Home Assistant apps for mac/iphone/ipad. You make a good point about using the accelerometer for compensating for the tanks. I thought about adding my own sensors and just leaving the SeeLevel ones in place. ... I'd also really like the propane level- Might could put a load cell under the tank and weigh it... There is custom code, not only for the UI but also integration for the accelerometer which is a custom little board I made. I used Codex to write most of the code... I setup the credentials and the Oliver was out in the driveway and Codex was logging into it and configuring. The most painful part of the whole deal was paying $49 and waiting 3 weeks for the Xantrex 40-pin connector!
  6. Thanks! Most everything is bluetooth (Victron, solar panels, solar charger, batteries, temperature sensors). I have a travel router (which I didn't mention), that is connected via ethernet. The GPS receiver connects via USB. The Xantrex was the tough one (and the best one to have). It has bluetooth, but in my experiments, it would disconnect immediately whenever I tried to send it a command. I think their phone app must have some "secret handshake" before it will work. So, I ordered a 40-pin connector that connects to the Xantrex and gives you a CAN bus interface over a shielded twisted pair cable. I then used a cheap ($20) USB CAN bus adapter connected to the Pi via USB. The Xantrex implements a subset of CANBUS called RV-C (RV industry related), so all the reading of values and setting variables is using the public RV-C protocol.
  7. I recently added a small single-board computer (Raspberry Pi) to my Oliver and a few other doodads that integrated everything into a single application called "Home Assistant". This is meant for home automation and control. Open-source, completely free. Rather than go into the details, I'll just show a few screenshots here. If anyone is interested in how/why, let me know and I could also do a "mods" video and show all the details. I sort of went down the rabbit hole on Home Assistant 😂. Here's the main screen- it shows a group of alarms across the top, from Victron, batteries, Xantrex, etc. I also have some little bluetooth temperature/humdity probes. I bought a 3-pack from Amazon and they were pretty cheap. One is mounted in the cabin, one under the propane cover and one in the fridge. You can set warning for high/low temp, so that's why the fridge is showing an alert (since it's turned off). I added a USB GPS receiver to the Raspberry Pi and it will display a little map of where the Oliver is. The "Temperatures" screen has all the temp/humidity sensors on one page The "Energy Flow" page is pretty interesting: I also added a 3D-accelerometer, but it is still an experiment. I plan on fixing the sensor to the hull and then implementing some kind of helper for leveling. I also wanted to track the amount of bumps and swaying that happen while towing. Not showing much right now since it is parked. Still playing with this one: More stuff on the main page: All this stuff is wired in and installed beneath the aft dinette seat. All the stats are logged indefinitely for now on an SSD drive, so you can pick a date/time range and see what was going on. I'm a bit of a geek if you can't tell 😁 One the very best benefits of all this is that I can see it from the HA app on my phone. I can also control things with the phone- I can remotely turn on/off the inverter, which lets me set it up so that I can go out and then use my phone to turn on the inverter (and AC if it is turned on). I think the only thing that is not being monitored is the fault code from the Progressive Industries EMS box. Let me know if you have any questions! -Steve
  8. Thanks Mike! it can be brutally hot down there, for sure. Even at the end of October, it was still in the 90s during the day.
  9. After a long wait, I have finally finished the Big Bend series from last year...
  10. I got the Oliver into a tight spot on a rough road in this one...
  11. I've been negligent in posting to my YouTube channel... More to come from last year's Big Bend trip...
  12. Just saw this- that is great! Glad to have played some part of your Oliver story. I was out this past weekend and was reminded how much I love this little camper. I’m coming up on my 3 year anniversary next month. Something about hopping in there just feels so much like home.
  13. Episode 18:
  14. Episode 17:
  15. Episode 16:
  16. Wish I had been able to stay the last day (I missed the BBQ), but had a good time and enjoyed seeing some familiar and new faces!
  17. I don’t know if anyone has seen this, but compare the time and energy to build an Oliver with this. This is 12 years old, and they were popping out a trailer in 7 hours. I missed the part where they did quality control 🤔 https://youtu.be/aLHux4SuXbY
  18. Absolutely! I went to the Oliver Texas rally as wellon the way out to Big Bend.
  19. It was fantastic, I could have spent another 2 weeks there...
  20. Been here for the last 5 days. Chihuahuan Desert, Big Bend NP
  21. Thanks, looking forward to it! I messaged with Cleo and unfortunately I'm going to have to miss the BBQ, I'll be leaving earlier on the 22nd. I did add my t-shirt size on the Google sheet.
  22. @Donna and Scott, I am signed up on the google sheet and I have reserved site # 33. I'll be there the 20th, staying 2 nights.
  23. Wow, I can't imagine a bike journey like that! Congrats to you for such a great accomplishment! I only rode about 70-80 miles per day in "flat" Iowa.
  24. I rode my bike across Iowa in RAGBRAI... It may net out to flat, but those rolling hills are a killer!
