NomadLife
1 Follower
1,068 profile views
NomadLife's Achievements
Apprentice (3/14)
16
  1. I would email them or call again. I am sure they got busy and forgot to get back to you.
  2. Which exact lube product do you utilize for this cable? Great idea, thanks!
  3. Great! I hope this works out!
  4. Which tire replacement Jack do you recommend we buy? I fled FL because my area got hit pretty good!
  5. Learning experience for me. Root cause was simply clogged toilet paper. I unclogged and all is fine now! I also now clean out the black tank more often, even when not full.
  6. September 10, 2024 Hello fellow Oliver Elite owners! I am letting everyone know that the Highsierra company has made a handheld bathroom faucet with adapter (chrome or brushed nickel) that fits the original Oliver hand held bathroom sink faucet plus hose and I LOVE this design! This way you no longer have to replace the whole faucet housing while looking great and you'll only need to replace the handheld part by screwing on the adapter to both the original hose (will only connect to the hose with the female threads) and Highsierra handheld shower head. Due to this handheld design and being metal not plastic, I noticed when I showered that my hot water lasted longer during cold weather and the force of the water was stronger than the original hand held. If interested, below is the link to the handheld faucet and you can call if you have any questions. I hope this helps! Highsierra Shower Heads Company # 1-888-445-1941 https://www.highsierrashowerheads.com/shop/rv-handheld-olivtrailers/F
  7. June 13, 2024 My black tank is FULL and will not drain! Since the outside Black Tank valve stem handle was pulled outward to open and it will not drain, I opened both the valve under the Dinette sink and the outside black tank valve handle but the black tank still will not drain. Does this mean I need to replace the outside valve? If yes, is anyone aware of a video on how to DIY this outside Black Tank valve? If DIY is not recommended, does anyone know of a reputable RV Mechanic in Pinellas County, Florida? I did call M. Sharpe of Oliver but while troubleshooting on the phone, the phone hung up. I called back and left a voicemail and waiting to hear back. Oliver Saleswoman said Oliver is having issues with their email system since I have not been hearing back from e-mails to M. Sharpe from last week. If anyone can provide any information on this situation, this would be helpful! Thank you everyone! KJ
  8. Thank you brother!
  9. June 4, 2024 Hello everyone! I am looking for front door electronic keypad that also has key access (as a backup) recommendations along with the associated Pro's and Con's to this specific lock. Providing the website link you purchased this from as well would be gratefully appreciated. Thank you! - KJ Hull # 600 (2020 E2)
  10. May 8, 2024 Is anyone aware of a reflective rooftop canopy (if not reflective & blocks sun well, this is ok) or tarp that fits nicely on the Elite 2 that will not suffocate my rooftop Houghton A/C and withstand the Florida sun? I am sure this does not matter but my OllieRhonda is a 2020. I did find this one in the below link but I'm looking for additional options. https://www.shaderv.com Thank you for your help!
  11. You're welcome! I remove the bracket (2 bumper bolts only) then re-install the 2 bolts only through the bumper for travel so the lights are not blocked. This is easier than removing 4 nuts from the U-clamps. The telescope pole allows me to keep the pole inside of my OE2. Hope this helps!
  12. Thank you! Regarding your questions, please message me when you get a chance.
  13. Here is my latest modification for an antenna pole holder. I used a 3” (bolt side) x 4” (height) x 5” (wide) .250 inch thick right angle with two .375 U-brackets while utilizing existing bumper bolts, washers, nuts and holes. I made sure the round pipe was 2 inches away from edge of the right angle aluminum (towards rear, away from Ollie) so that this pipe did not interfere with the swinging bumper when closing/pinning with locking pins. Make sure the 2 holes in the right angle are away from the right angle radius so that the large existing washers will not be on top of this radius (so washers are flush on top of metal). The U-brackets will allow you to move the pole upward or downward, along with removal for when towing so the lights are not blocked. The 22 ft flag pole I purchased is fiberglass from polesandholders.com and it is collapsible. The flagpole holders from this site will not work for my chosen bumper location. The inside flagpole holder pipe diameter will be determined by your flagpole outside diameter measurement.
  14. Looking at Foy's Twin bed modification PDF file photos, we don't have to remove the "side extensions" (drilling out rivets). What approach did you end up going with for this bed space modification? Kevin
  15. Hello to all! I'm looking for recommendations for a 5 or 7 cubic feet chest freezer that would fit through the doorway. I am a carnivore, so I order my meat in bulk and I will place this freezer in the dinette area or at one of the twin bed areas. It is a challenge finding widths that will fit through the entrance opening. Thanks!
