I have been using this for about a year and it works great. The app is wonderful to use remotely to check temperature and make changes remotely on the fly i.e. if it is getting cold for the night or you need to check on pets. Works off of bluetooth or WIFI. Super easy install. The unit itself is touchscreen and easy to navigate.
I know it works for the Dometic Penguin II, not sure about the Truma (it is not listed as compatible).
link:
https://www.microair.net/pages/the-easytouch-rv-wifi-thermostat?gad_source=1
Edited by rideadeuce
Thanks for that, we're going to try it based on your stellar recommendation
Albert & Terri Sterns
Paonia, Colorado
Looks great. Excellent Job! Do you know of the amount of watts its drawing? It has to add a little more current draw to the system?
2021 Legacy II Hull #728 Pulled by 2015 Toyota Tundra 5.7 with 6.6 bed with Decked pullout.
300 Watt Bouge cigs flat solar. dual 30# propane tanks w/GasStop safety devices and Mopeka tank sensors, Victron Multiplus II 12volt., 400 x Battleborn Batteries ,Victron SmartShunt, Victron cerbo and screen. 2 x Victron Smart solar 100/30 and 1 x Smart solar 100 x 15. 800 watts ground panels. Mopeka tank sensors x 2 , Tempature sensors fridge battery compartment Ruuvi tags with fans. 12 volt  Nova Kool refrigerator. Tosot A/C.  Pecron E3600 + 2000 and 2000 Batteries with victron Orion 50amp dc to dc charger.Electric water valves and IRVWPC2 water pump controller. Truma on demand water heater. Added outdoor side Table. Bumper Toolbox, and Many more mods thank you contributors!
Minimal current draw - we’ve had ours since last May.  Great control for the Dometic A/C and furnace units….  We love ours!
  • (SOLD) 2022 TUNDRA
