I'm adding a Renogy 400W solar suitcase and onboard Victron 100/30 charge controller to my solar setup via the existing Zamp solar port. The existing Zamp connection/setup does not have a solar disconnect like my roof top solar has. However, the stock Zamp setup is geared towards an external solar panel/suitcase with integrated charge controller. So, is a solar disconnect required with a ground deployed suitcase and onboard charge controller? My concern is, it might cause an arc if no disconnect switch and I remove/pull the solar suitcase connector from the Zamp external connector.
**Sold😞**
Hull #193 did not have an OEM supplied disconnect, so I would get a ladder out and cover the solar panels with a tarp or moving blanket.  That process got old in a hurry, so I added a disconnect between the panels and CC.  There are lots of choices for this task, but this what I used.
IMG_1275.thumb.jpeg.8f1ec4ee48cf17584952d80bed268441.jpegIMG_1273.thumb.jpeg.a20c2f70578c30d407dd988ad8c1b0e7.jpeg
Thanks Mossey, I understand you need a disconnect for the permanently mounted rooftop solar. Sorry if I wasn’t clear in my original post. I have the factory 400W solar on the roof with Victron MPPT 100/50 CC and disconnect in the cubby above the street side bed. I now want to add an additional 400W Renogy suitcase to connect with the stock outside Zamp port per my above sketch. Do I need a disconnect for this setup? Like I said in my original post, my concern is plugging in and out the external suitcase might cause an arc in the external Zamp connection and solar suitcase plug if there's no disconnect switch between the Zamp port and new Victron 100/300 CC.
**Sold😞**
Why not just cover the Victron or lay it face down so it is not producing power before disconnecting, if you are concerned?
Maine
Any reason for installing the charge controller for the suitcase panels in the trailer?
Steve & Mary Allyn
San Antonio, TX
To reduce voltage loss, here are a Couple videos explaining it.
…….and
**Sold😞**
That makes sense, and with only 15' of 8 AWG wire connected directly to the panels the voltage drop before reaching the CC will be minimal.
Steve & Mary Allyn
San Antonio, TX
I think a disconnect is a good idea whether it is required or not.  My Furrion external solar port, which I installed, does not have a dedicated disconnect, but it does have a 10A inline fuse.  My Renogy100W suitcase panels with onboard CC are foldable as the name suggests and that’s what I do.  I work the cable connections from the external solar port out towards the panels with the MC4 connections last.  I think the MC4 connectors are less likely to arc, but I still like the manual breaker solution.  Now you just need to figure out where to put it.
