rich.dev Posted April 27, 2024 Posted April 27, 2024 I'm adding a Renogy 400W solar suitcase and onboard Victron 100/30 charge controller to my solar setup via the existing Zamp solar port. The existing Zamp connection/setup does not have a solar disconnect like my roof top solar has. However, the stock Zamp setup is geared towards an external solar panel/suitcase with integrated charge controller. So, is a solar disconnect required with a ground deployed suitcase and onboard charge controller? My concern is, it might cause an arc if no disconnect switch and I remove/pull the solar suitcase connector from the Zamp external connector. **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Moderators mossemi Posted April 27, 2024 Moderators Posted April 27, 2024 1 hour ago, rich.dev said: I'm adding a Renogy 400W solar suitcase and onboard Victron 100/30 charge controller to my solar setup via the existing Zamp solar port. The existing Zamp connection/setup does not have a solar disconnect like my roof top solar has. However, the stock Zamp setup is geared towards an external solar panel/suitcase with integrated charge controller. So, is a solar disconnect required with a ground deployed suitcase and onboard charge controller? My concern is, it might cause an arc if no disconnect switch and I remove/pull the solar suitcase connector from the Zamp external connector. Hull #193 did not have an OEM supplied disconnect, so I would get a ladder out and cover the solar panels with a tarp or moving blanket. That process got old in a hurry, so I added a disconnect between the panels and CC. There are lots of choices for this task, but this what I used. Mossey 1 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
rich.dev Posted April 27, 2024 Author Posted April 27, 2024 Thanks Mossey, I understand you need a disconnect for the permanently mounted rooftop solar. Sorry if I wasn’t clear in my original post. I have the factory 400W solar on the roof with Victron MPPT 100/50 CC and disconnect in the cubby above the street side bed. I now want to add an additional 400W Renogy suitcase to connect with the stock outside Zamp port per my above sketch. Do I need a disconnect for this setup? Like I said in my original post, my concern is plugging in and out the external suitcase might cause an arc in the external Zamp connection and solar suitcase plug if there's no disconnect switch between the Zamp port and new Victron 100/300 CC. **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
dewdev Posted April 27, 2024 Posted April 27, 2024 Why not just cover the Victron or lay it face down so it is not producing power before disconnecting, if you are concerned? 3 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Steve and MA Posted April 27, 2024 Posted April 27, 2024 Any reason for installing the charge controller for the suitcase panels in the trailer? Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
rich.dev Posted April 27, 2024 Author Posted April 27, 2024 9 minutes ago, Steve and MA said: Any reason for installing the charge controller for the suitcase panels in the trailer? To reduce voltage loss, here are a Couple videos explaining it. …….and 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Steve and MA Posted April 27, 2024 Posted April 27, 2024 That makes sense, and with only 15' of 8 AWG wire connected directly to the panels the voltage drop before reaching the CC will be minimal. 1 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
Moderators mossemi Posted April 29, 2024 Moderators Posted April 29, 2024 On 4/27/2024 at 9:38 AM, rich.dev said: Do I need a disconnect for this setup? Like I said in my original post, my concern is plugging in and out the external suitcase might cause an arc in the external Zamp connection and solar suitcase plug if there's no disconnect switch between the Zamp port and new Victron 100/300 CC. I think a disconnect is a good idea whether it is required or not. My Furrion external solar port, which I installed, does not have a dedicated disconnect, but it does have a 10A inline fuse. My Renogy100W suitcase panels with onboard CC are foldable as the name suggests and that’s what I do. I work the cable connections from the external solar port out towards the panels with the MC4 connections last. I think the MC4 connectors are less likely to arc, but I still like the manual breaker solution. Now you just need to figure out where to put it. Mossey 3 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
