Brian Z Posted June 14 Posted June 14 We have a 2020 Legacy Elite II with a Truma water heater. This spring, we are unable to get it to heat the water. There are no warning codes on the panel or on the water heater. When you turn the water heater switch and panel switch to on, and watch the water heater, you can see the flame start. Hot air blows out. It will start and stop two or three times. Then when you go into the camper and turn on the hot water faucet, the water never gets hot. When you go look at the water heater, it looks like the flame is not starting and no hot air is being blown out. I would have decalcified it but we do not have any decalcification tablets. The propane stove and furnace work great. Does anybody have any experience or ideas with this? Thanks much, in advance!
Ray Kimsey Posted June 14 Posted June 14 I assume your water heater bypass valve is set correctly? That is the only thing I can think of at the moment. 1 2019 Ram 1500 5.7L V8, 3.92 axle ratio - 2020 LEll - Hull676
Brian Z Posted June 14 Author Posted June 14 Thanks Ray! I thought I had tried both the open and bypass modes. However, I decided to try and turn the valve more to the right and it did turn more. I was afraid of breaking it off with my pliers. When I turned it more to the right, I finally did get hot water! Oliver refers to a lever or handle on the valve. It would be nice if there actually was a lever or handle on that valve but alas there in fact, is NO handle or lever. I have always used a pliers. Guess I better submit a ticket Oliver to get me that valve handle/lever! Thanks again!
Galway Girl Posted June 14 Posted June 14 There is a green LED light directly above the Truma Exterior switch. That LED glows green when all is ok. It flashes a code if something is wrong. You could then look up the code in the Truma manual or here: truma-operating-instructions-error-codes-water-aquago-us-en-ca-fr-mx-es.pdf If your LED is glowing solid green and you're only seeing very lightly warmed water then the issue could be as follows: Check: Make sure the street side outside shower valves are both actually turned all the way off. The shower head has a on/off push button so while it may appear the water is off, if t's simply off at the shower head and those valves are on the hot and cold side water are mixing in the lines and the water heater will not heat up the supply. Reason this happens: Often this happens when owners flush the system of the winter antifreeze or after winter storage. They forget to turn OFF both valves on the shower because there wasn't any water coming out of the shower wand. (Because it's locked in the off position). Craig Short Galway Girl - Hull 505 2019 Elite II (Hull 505 - Galway Girl - August 7, 2019 Delivery) Tow Vehicle: 2021 F350 King Ranch, FX4, MaxTow Package, 10 Speed, 3.55 Rear Axle Batteries Upgrade: Dual 315GTX Lithionics Lithiums - 630AH Total Inverter/Charger: Xantrex 2000Pro Travel BLOG: https://4-ever-hitched.com
jd1923 Posted June 14 Posted June 14 12 minutes ago, Brian Z said: ... I decided to try and turn the valve more to the right and it did turn more. I was afraid of breaking it off with my pliers. When I turned it more to the right, I finally did get hot water! On a 1/4 turn valve it should turn 90 degrees by hand, w/o requiring pliers. If you are sure you are in the 90-degree range, use your pliers and move it hard and quickly back and forth, stop to stop. There could be sediment in there. If you cannot free it up nicely, replace it with a higher quality valve. Or be removing the valve maybe it can be cleaned up inside. Hope this helps! Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Ray Kimsey Posted June 14 Posted June 14 (edited) 1 hour ago, Brian Z said: Thanks Ray! I thought I had tried both the open and bypass modes. However, I decided to try and turn the valve more to the right and it did turn more. I was afraid of breaking it off with my pliers. When I turned it more to the right, I finally did get hot water! Oliver refers to a lever or handle on the valve. It would be nice if there actually was a lever or handle on that valve but alas there in fact, is NO handle or lever. I have always used a pliers. Guess I better submit a ticket Oliver to get me that valve handle/lever! Thanks again! @Brian Z It should turn 90 degrees. I have a 2020 also. Check around in that space around the heater for the lever. Mine vibrated loose a year or so ago and I was able to find it and put it back on. Edited June 14 by Ray Kimsey 1 2 2019 Ram 1500 5.7L V8, 3.92 axle ratio - 2020 LEll - Hull676
Brian Z Posted June 15 Author Posted June 15 Thank you all! It is great what you can learn from the forum! 1 2
silversportsman Posted August 31 Posted August 31 On 6/14/2024 at 3:33 PM, Ray Kimsey said: I assume your water heater bypass valve is set correctly? That is the only thing I can think of at the moment. I am a new Oliver LE owner, and bringing this topic back to the top because I am having a similar issue with my Truma. However, I don't see the bypass valve that you are referring to. Do you have a picture, or would you like me to send a picture of mine?
rich.dev Posted August 31 Posted August 31 (edited) 42 minutes ago, silversportsman said: I am a new Oliver LE owner, and bringing this topic back to the top because I am having a similar issue with my Truma. However, I don't see the bypass valve that you are referring to. Do you have a picture, or would you like me to send a picture of mine? Below pictures show a Truma Water Heater bypass valve currently set in winterization mode. You will need to turn the valve towards you to open the flow for cold water to enter the water heater chamber. ....and check from time stamp 5:14 in below video. Edited August 31 by rich.dev 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
silversportsman Posted August 31 Posted August 31 10 minutes ago, rich.dev said: Below pictures show a Truma Water Heater bypass valve currently set in winterization mode. You will need to turn the valve towards you to open the flow for cold water to enter the water heater chamber. Dumb question but where is that circular port hole? I am looking at the water heater from under the flip down panel on the outside curbside behind the tire.
rich.dev Posted August 31 Posted August 31 (edited) 5 minutes ago, silversportsman said: Dumb question but where is that circular port hole? I am looking at the water heater from under the flip down panel on the outside curbside behind the tire. That access port is on the side of the curb side bed, you can also access that valve by removing the rear access panel above the curb side bed, check from time stamp 5:14 in this video clip. Edited August 31 by rich.dev 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
silversportsman Posted August 31 Posted August 31 @rich.dev you are my new best friend. 🙂 We have hot water. I should have mentioned that we have the LE I, so it looks a little different but not much. I had not yet seen the video you linked so that was very helpful. Thanks a bunch, and have a great holiday weekend. Hope to see you at an upcoming rally and thank you in person. Bob (and Barb) Campbell 2
