GlacierGirl Posted 8 hours ago Share Posted 8 hours ago I am Barb's husband, Mark. I can't turn on the xantrax freedom x to get ac power. I press the button on the wall mounted moniter/display, but nothing happens? Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia Link to comment Share on other sites More sharing options...
Steph and Dud B Posted 8 hours ago Share Posted 8 hours ago I assume you are not plugged into shore power and are running on batteries? Is the silver button on the Xantrex wall panel in the In position or Out? Are there any green LEDs lit on the panel? Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
GlacierGirl Posted 8 hours ago Author Share Posted 8 hours ago Thanks, steph and dud b. The button on the inverter box down below my bed was off. I guess I must have turned it off? I pressed it again, so the button was out, and my control screen on the wall came on. So, the two buttons operate opposite , one out, down below, one in up above. Go figure? But now all is working fine. Thanks so much for your reply. Barb (and husband, Mark) in Estes Park, CO / Elite 2, Hull #941 / 2023 Toyota Sequoia Link to comment Share on other sites More sharing options...
Steph and Dud B Posted 8 hours ago Share Posted 8 hours ago Glad you fixed it! Stephanie and Dudley from CT. 2022 LE2, Hull #1150: Eggcelsior. Tow vehicle: 2016 GMC Sierra 6.0 gas dually 4x4. Our Oliver journey: Steph and Dud B's RV Screed Where we've been RVing since 1999: Link to comment Share on other sites More sharing options...
Ronbrink Posted 1 hour ago Share Posted 1 hour ago 6 hours ago, GlacierGirl said: So, the two buttons operate opposite , one out, down below, one in up above. There is a chance the wall-mounted remote button is not working, they can fail which happened with mine. If your remote is the BT model, there is a procedure to supposedly restore communication and use of the remote button. Mine is not BT and the fix is a replacement remote. I decided to use the button on the inverter to operate and just leave it on. Regardless of the remote model, the buttons will have the same operating positions as the inverter. 2020 OLEll, Twin, 579: No installed solar, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, Hughes Autoformer, dual Lagun tables, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, Dreiha Atmos 4.4 a/c upgrade. 2019 GMC Savana 2500 Cargo Van: 6.0L V8 Vortec, 6-Speed Automatic; Explorer Limited SE, Low-Top 7 Passenger van conversion, RWD. Link to comment Share on other sites More sharing options...
