TxMN2020 Posted December 1 Posted December 1 I use a 12v milwaukee grease gum with lock n lube attached to flexible hose. We plan to pickupy our Oliver this month, jest trying to get a few Service temp together. Will this set up work for Oliverx lubrication needs? i mosty use Lucas Red and Tacky around The farm 2
Moderators SeaDawg Posted December 2 Moderators Posted December 2 Many people use the lock n lube. I'm sure you are looking forward to picking up your new Ollie soon. Congratulations. I'm sure you'll get comments on the gun from others who've used it. 2 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Rivernerd Posted December 2 Posted December 2 17 hours ago, TxMN2020 said: i mosty use Lucas Red and Tacky around The farm Oliver uses Mystik Red grease at the factory. If Lucas Red "N" Tacky is compatible with Mystik, you should be "good to go". I am also a Lock N Lube fan. 2 Hull #1291 Central Idaho 2022 Elite II Tow Vehicle: 2019 Tundra Double Cab 4x4, 5.7L with tow package
Geronimo John Posted 15 hours ago Posted 15 hours ago Ditto: Lock N Lube, Mystic in my axle zerks and CV-2 on the bearings. That said, when I run out of CV-2 (In about 8 years) I'll go with the Dexter Mobile Synthetic bearing grease. It is specifically called out in the EZ Flex installation procedure that I posted earlier today. GJ 1 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
