Rich and Jane Walker Posted January 9 Posted January 9 Is there a trick to get the screens past the roller shades once you pop the screen out of the track? There doesn’t seem to be much clearance and I don’t want to permanently deform the screen frame. TIA and greetings from Gulf State Park! 2024 Chevrolet Silverado Duramax 3.0L 2024 Legacy Elite 2, Lithium Platinum package, twin bed, Truma AC Hull 1526 Palos Heights, Illinois
rich.dev Posted January 9 Posted January 9 (edited) Your 2024 has roller shades, our 2023 has accordion shades, did you switch them out? Must say I’m a little confused (maybe just me😊) as to exactly what you want to do here. If what you want to do is remove the screen completely, you have to pop off the accordion shades frame first, just pull firmly on the corners. Edited January 9 by rich.dev 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Rich and Jane Walker Posted January 9 Author Posted January 9 Here is a picture of the shades. I want to remove the screens to clean them. I see an earlier post which says the shades must be removed before removing the screen but not sure how. Thanks. 2024 Chevrolet Silverado Duramax 3.0L 2024 Legacy Elite 2, Lithium Platinum package, twin bed, Truma AC Hull 1526 Palos Heights, Illinois
rich.dev Posted January 9 Posted January 9 Yes I edited my op before seeing your response, you have to remove the shade frame, just pull firmly on the corners. 1 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Rich and Jane Walker Posted January 9 Author Posted January 9 Thanks Rich- after being a bit apprehensive to pull off, it worked. Straightforward and simple once a newby gets good advice! 1 2024 Chevrolet Silverado Duramax 3.0L 2024 Legacy Elite 2, Lithium Platinum package, twin bed, Truma AC Hull 1526 Palos Heights, Illinois
rich.dev Posted January 9 Posted January 9 4 minutes ago, Richard Walker said: Thanks Rich- after being a bit apprehensive to pull off, it worked. Straightforward and simple once a newby gets good advice! Nice! Also, if you want you can flip the shades so you can open the night shade from top down as opposed to bottom up, see this post. 2 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Moderators topgun2 Posted January 9 Moderators Posted January 9 Rich - Now that you have the screens removed for cleaning: If you live in or travel to any area of the country that has "no-see-ums" you might consider replacing the screen material with material that has a smaller/finer mesh such that these biting little critters can't get in. There is nothing "wrong" with the standard screen material except that the mesh (the small holes in the screen) is big enough for these (and other) small insects to crawl through. There are a number of YouTube videos on how to easily tackle this job - https://www.youtube.com/watch?v=t7emMleueHg Good luck. Bill 2 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
johnwen Posted January 9 Posted January 9 4 minutes ago, topgun2 said: you might consider replacing the screen material with material that has a smaller/finer mesh We did this to our Casita and Oliver...quite an improvement but some of the tinyest,unidentified critters still manage to infiltrate. We are happy we did this modification and do recommend it! :) Best of luck, John 3 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Patriot Posted January 9 Posted January 9 11 minutes ago, johnwen said: We did this to our Casita and Oliver...quite an improvement but some of the tinyest,unidentified critters still manage to infiltrate. We are happy we did this modification and do recommend it! 🙂 Best of luck, John Agreed, having lived a few years in no see um South Georgia/North Florida coast we found it’s just best to keep the windows closed and the AC on. We called those pests a flying set of teeth. 😂 2 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
Rich and Jane Walker Posted January 10 Author Posted January 10 Thanks to everyone for the good suggestions. Much appreciated! 1 2024 Chevrolet Silverado Duramax 3.0L 2024 Legacy Elite 2, Lithium Platinum package, twin bed, Truma AC Hull 1526 Palos Heights, Illinois
