@Ronbrink  I will warn you about opening that can of worms, if you think working under the beds or the dinette seats is hard on your back, just wait until you pull the vanity door off.
And, unless you are about the size of and have the agility of a spider monkey, forget about getting your head inside to see and your arm (forget both arms also) inside to work at the same time.
But, taking out the vanity insert and replacing it with an access door is one of the handiest mods I've done. I literally use that access all the time.
On 8/16/2025 at 7:55 AM, mossemi said:
2017 #193 does not have that crazy junction box under the bath vanity either, but I sure wish it did!  It sure would make troubleshooting 7 pin power problems easier for me!
Yeah, I was suprised to find a residential-type galvanized junction box for the 7-pin connection....but it was located close to where the 7-pin trailer wire comes into the hull behind the propane tanks.  My 7-pin cable was damaged and I found it easy to replace it with a new one while I was in there.  It seems to work just fine...
If you ever need another surprise, look for the 120V outlet for the refrigerator and I’ll bet a cup of coffee it is a metal outlet box as well.  The good news is that you won’t find a broken blue outlet box!
