dmtaylor2 Posted April 3, 2025 Posted April 3, 2025 Hull #527 ready for carrying bikes! After the factory tour, I wanted a bike rack receiver hitch but NOT the one they sold. At the time there was not a safe option for an 2” receiver. After buying a used LE II, I decided to look for a good welder. I am happier than ever with the way this turned out and at a fraction of the price. 1 3
Wandering Sagebrush Posted April 3, 2025 Posted April 3, 2025 Is that aluminum, or steel? Looks secure. Hull #364 - The Roadrunner 2023 F350 CCLB SRW 6.7L
dmtaylor2 Posted April 4, 2025 Author Posted April 4, 2025 Steel, but square tube. Couldn’t be happier. 4 hours ago, Wandering Sagebrush said: Is that aluminum, or steel? Looks secure.
DanielBoondock Posted May 15, 2025 Posted May 15, 2025 Weight rating? The hitch will handle a lot, question is the bumper itself. The stock one is rated at 100 lbs which won’t work for me as my Kuat Piston Pro is 63 lbs by itself and I have heavy eBikes. Ultiumately not a problem, I’ll keep the bikes in the truck bed and swap the bike rack for the rear shelf storage. Wouldn’t hurt to have the option though. Oliver Elite II Twin (order late summer for MY2026)
rich.dev Posted May 15, 2025 Posted May 15, 2025 4 minutes ago, DanielBoondock said: The stock one is rated at 100 lbs which won’t work for me as my Kuat Piston Pro is 63 lbs by itself and I have heavy eBikes. Actually it was upgraded to 150lbs a few years ago. 1 **Sold😞** 2023 Elite II, Hull# 1386, Lithium Platinum Package (640AH, 400W Roof Solar, 3000W Xantrex Inverter), added 400W Renogy Solar suitcase with Victron MPPT 100/30 CC, Truma water heater & AC TV: 2024 Silverado 2500HD 6.6L 10-Speed Allison
Jason Foster Posted May 15, 2025 Posted May 15, 2025 On 4/3/2025 at 9:11 PM, dmtaylor2 said: Steel, but square tube. Couldn’t be happier. How did you address galvanic corrosion? 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Moderators topgun2 Posted May 15, 2025 Moderators Posted May 15, 2025 8 hours ago, Jason Foster said: How did you address galvanic corrosion? SIR? 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Jason Foster Posted May 15, 2025 Posted May 15, 2025 1 hour ago, topgun2 said: SIR? Dissimilar metal corrosion. Aluminum bumper and steel bolts, frame etc. 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
Moderators topgun2 Posted May 15, 2025 Moderators Posted May 15, 2025 2 hours ago, Jason Foster said: Dissimilar metal corrosion. Aluminum bumper and steel bolts, frame etc. OK then, how about MRS.?😁 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Jason Foster Posted May 15, 2025 Posted May 15, 2025 49 minutes ago, topgun2 said: OK then, how about MRS.?😁 Yes. They might have something. Lol https://www.mrs.org/ 1 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
