John and Debbie Posted May 12, 2025 Posted May 12, 2025 Hi all, we have the Norcold three way refrigerator that has a large vent on the bottom with three air intake slats and a smaller one on top with I believe five slats. I installed three metal screens on the lower one to keep bugs out. It's designed for that purpose so should work well. Does anyone do anything on the upper vent? If I was a smart bug I would just enter through the top uncovered vent. I don't want to go too crazy and impede the exhaust air unless it's ok. Thanks, John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
johnwen Posted May 12, 2025 Posted May 12, 2025 (edited) 4 hours ago, John and Debbie said: Hi all, we have the Norcold three way refrigerator that has a large vent on the bottom with three air intake slats and a smaller one on top with I believe five slats. I installed three metal screens on the lower one to keep bugs out. It's designed for that purpose so should work well. Does anyone do anything on the upper vent? If I was a smart bug I would just enter through the top uncovered vent. I don't want to go too crazy and impede the exhaust air unless it's ok. Thanks, John Yes, John, Oliver used to sell those upper screens...don't know if they still do. We used small zip ties to hold them in place. Been there for 3+years...no problems. Good Luck, John Amended...forget the zip ties, not needed. I was reverting back to my old Casita days :) Patriotus gave you the correct info! And the mother ship may still have some in stock. John Edited May 12, 2025 by johnwen 3 2022 Oliver II #996 "Bessie", 2019 Silverado LTZ 5.3, Veterans https://wenandjohnsadventure.com/
Patriot Posted May 12, 2025 Posted May 12, 2025 (edited) @John and Debbie Here you go and it’s even on sale! 👍🏻 https://www.etrailer.com/Accessories-and-Parts/Valterra/A10-1314VP.html?feed=npn&gad_source=1&gad_campaignid=1672411894&gclid=CjwKCAjwuIbBBhBvEiwAsNypvQ1XKW9UZOvykONtRfVuZZ7Oa3mCtQb5eZYfkAeF53AIxmbXV19a9hoC2MYQAvD_BwE This looks exactly like the screen I installed. Patriot🇺🇸 Edited May 12, 2025 by Patriot 1 3 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
John Dorrer Posted May 13, 2025 Posted May 13, 2025 We had Oliver install bug screens on the fridge and furnace at original pick-up. 2 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
John Dorrer Posted May 13, 2025 Posted May 13, 2025 7 hours ago, John and Debbie said: Hi all, we have the Norcold three way refrigerator that has a large vent on the bottom with three air intake slats and a smaller one on top with I believe five slats. I installed three metal screens on the lower one to keep bugs out. It's designed for that purpose so should work well. Does anyone do anything on the upper vent? If I was a smart bug I would just enter through the top uncovered vent. I don't want to go too crazy and impede the exhaust air unless it's ok. Thanks, John Screens on both for us 1 John & Susan Dorrer, 2013 F250, 6.2 gasser, 4x4, 2022 Legacy Elite 2, twin beds, Hull #1045, Jolli Olli -
John and Debbie Posted May 13, 2025 Author Posted May 13, 2025 On 5/12/2025 at 2:20 PM, Patriot said: @John and Debbie Here you go and it’s even on sale! 👍🏻 https://www.etrailer.com/Accessories-and-Parts/Valterra/A10-1314VP.html?feed=npn&gad_source=1&gad_campaignid=1672411894&gclid=CjwKCAjwuIbBBhBvEiwAsNypvQ1XKW9UZOvykONtRfVuZZ7Oa3mCtQb5eZYfkAeF53AIxmbXV19a9hoC2MYQAvD_BwE This looks exactly like the screen I installed. Patriot🇺🇸 My cover is 62053 but has the correct dimensions. The link you sent was for 620505. I can't find a screen that goes with my number. The upper outer grill looks the same. Does your plastic grill have the number 62053? John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
jd1923 Posted May 18, 2025 Posted May 18, 2025 (edited) Thanks @John and Debbie for bringing this to my attention. We have the Dometic vs. Norcold, but when I noticed the $40 for the screen, I thought I could easily fab one. I had purchased this 6" roll of metal screening from True Value years ago to bug/rodent-proof our home, so this time there was zero additional cost. Turns out 6" was just enough to cover with a 3/4" bend on three sides. It takes a bit of measuring cutting and bending to get it right. Be careful, the screen will draw blood. To attach the screen to the cover I used 2 rivets on each side. When done I had a small hole on each side so cut a small square of foam to fill in these gaps. I think it turned out well, in fact these covers used to be lose even though I purchased new OEM plastic mount screws. With the screens on it took a little push to get into the recess but it's in there tight, no more wiggle! Second pic shows the tools required and then vent cover installed. If you zoom into the second picture you can just see the rivets on the end and zoom in on the last picture and you can see the screening inside the vent cover. Edited May 18, 2025 by jd1923 2 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Jason Foster Posted May 18, 2025 Posted May 18, 2025 1 hour ago, jd1923 said: Thanks @John and Debbie for bringing this to my attention. We have the Dometic vs. Norcold, but when I noticed the $40 for the screen, I thought I could easily fab one. I had purchased this 6" roll of metal screening from True Value years ago to bug/rodent-proof our home, so this time there was zero additional cost. Turns out 6" was just enough to cover with a 3/4" bend on three sides. It takes a bit of measuring cutting and bending to get it right. Be careful, the screen will draw blood. To attach the screen to the cover I used 2 rivets on each side. When done I had a small hole on each side so cut a small square of foam to fill in these gaps. I think it turned out well, in fact these covers used to be lose even though I purchased new OEM plastic mount screws. With the screens on it took a little push to get into the recess but it's in there tight, no more wiggle! Second pic shows the tools required and then vent cover installed. If you zoom into the second picture you can just see the rivets on the end and zoom in on the last picture and you can see the screening inside the vent cover. That looks great. I don’t have that fridge, so no vent, but I do have other areas that need critter protection. 1 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
