T-Oliver Posted May 12 Posted May 12 2017 Oliver While staring at the wiring around the charge controller (trying to make sense of it). I noticed this, after 7 years… No wonder the hose on the outside shower seemed less than useful. 4
Zodd Posted May 12 Posted May 12 Looks like someone was not paying attention when installing the jack. Todd & Kat 2023 LE ll twin, hull # 1305, Truma AC & WH, Platinum solar, Natures Head 2024 Ford F250 Lariat 7.3L gasser / 3.75, FX4
Jason Foster Posted May 12 Posted May 12 That jack installation is too involved to miss a shiny chrome hose wrapped around it. My guess is that the hose was install, or reinstalled after a problem, and was accidently wrapped around the jack. Of course, no one checked to see if the hose had full mobility before the sent it out the door. 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
jd1923 Posted May 13 Posted May 13 That hose must have been wrapped around the jack on purpose. The dang hose gets caught on something always. OTT should have it in a holding tube so that it can be pulled out and back in smoothly. OTT installs the shower head with hard 90 degree PEX and our gets caught on that often. I have to get under my bed AGAIN to free it before our next trip. I've wrapped the 90s with loom and it hasn't helped. I need to figure out something else this time. I need the FULL length of the hose to fit it into an exterior mount I added to get it held above my head height! Like to shower outside whenever we're boondocking in decent weather. The inside shower isn't tall enough and I prefer not getting the bathroom wet. Our wet-bath shower is mainly for Chris. I've only used it a few times. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted May 13 Posted May 13 I attached a nylon mesh bag on the back to keep the hose from catching on anything. Before that it was always push-pull until I was able to get the whole line out. 1 1 2010 Elite II, Hull #45. 2014 Toyota Sequoia Platinum 4WD 5.7 with tow package.
jd1923 Posted May 14 Posted May 14 7 hours ago, CRM said: I attached a nylon mesh bag on the back... How did you attach it, fix it so it will stay put? Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
CRM Posted May 14 Posted May 14 10 minutes ago, jd1923 said: How did you attach it, fix it so it will stay put? I weaved a large zip tie used for air conditioning ductwork through the top of the mesh bag to make a "mouth" in it that would keep it's shape. I then used two smaller zip ties to mount it to the dump valve cables that are on each side of where the shower hose is so the shower hose would always stay in the bag. My setup looks much different than yours from the back so I don't know if this method would work for you or not. 1 2010 Elite II, Hull #45. 2014 Toyota Sequoia Platinum 4WD 5.7 with tow package.
Jason Foster Posted May 14 Posted May 14 9 hours ago, jd1923 said: That hose must have been wrapped around the jack on purpose. The dang hose gets caught on something always. OTT should have it in a holding tube so that it can be pulled out and back in smoothly. OTT installs the shower head with hard 90 degree PEX and our gets caught on that often. I have to get under my bed AGAIN to free it before our next trip. I've wrapped the 90s with loom and it hasn't helped. I need to figure out something else this time. I need the FULL length of the hose to fit it into an exterior mount I added to get it held above my head height! Like to shower outside whenever we're boondocking in decent weather. The inside shower isn't tall enough and I prefer not getting the bathroom wet. Our wet-bath shower is mainly for Chris. I've only used it a few times. I haven't looked inside that area with the mindset of correcting this problem, but why couldn't you use a plastic slip sheet, cut to length, fold it over to make a loose tube and rivet it together. The hose should nest inside of the tube and will keep it from catching on anything. Slip Sheets | Signode 1 2014 Ram 2500 Cummins Diesel 4X4 Truck 2024 Oliver Legacy Elite II Hull 1460
