John and Debbie Posted May 22, 2025 Posted May 22, 2025 Hi all, we have a Visio TV that works at home by the garage hooking up to the Wi-Fi at home. The Grand Junction, Colorado KOA shows strong Wi-Fi but when I try to access it and I choose GrandJunctionKOA it says,"no internet" and doesn't progress to the next step of putting in the code. Any idea how to solve this? Thanks John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
CRM Posted May 22, 2025 Posted May 22, 2025 5 minutes ago, John and Debbie said: Hi all, we have a Visio TV that works at home by the garage hooking up to the Wi-Fi at home. The Grand Junction, Colorado KOA shows strong Wi-Fi but when I try to access it and I choose GrandJunctionKOA it says,"no internet" and doesn't progress to the next step of putting in the code. Any idea how to solve this? Thanks John The campground might have a webpage that must be accessed first to accept terms before entering the network key. I had this happen once before and I just ended up streaming from my phone to the TV instead. 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Rolind Posted May 22, 2025 Posted May 22, 2025 I would talk to the office at the KOA in the morning. I know at the Charleston KOA has a number to call if you are streaming on their WiFi. No extra charge involved, just a few extra steps. 1 Robert and Cheryl, Louisville, KY, Legacy Elite II Hull #1390 Oliphino, TV F250 Tremor
John and Debbie Posted May 22, 2025 Author Posted May 22, 2025 22 minutes ago, CRM said: The campground might have a webpage that must be accessed first to accept terms before entering the network key. I had this happen once before and I just ended up streaming from my phone to the TV instead. How do you stream from your phone? I am not tech savvy. Any easy steps to take? John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
CRM Posted May 22, 2025 Posted May 22, 2025 7 minutes ago, John and Debbie said: How do you stream from your phone? I am not tech savvy. Any easy steps to take? I have an HDMI cable that connects my phone to the TV. I'm sure there are other ways but it's probably going to be tricky if the phone and TV are not on the same WiFi network. You might also want to try setting up your phone as a WiFi hotspot and then connecting your tv to it. 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Patriot Posted May 22, 2025 Posted May 22, 2025 (edited) 5 hours ago, John and Debbie said: Any idea how to solve this? The Starlink Mini is in sale right now for $299.00 and makes streaming a breeze. 😊 We also stayed at that same KOA when we got our Alcan leaf pack installed. We were glad to have the Mini and it worked great. Congrats on the Alcan’s! https://www.starlink.com/roam Edited May 22, 2025 by Patriot 1 2 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles.XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. ⚡️⚡️11/2025- Lithium upgrade to XPLOR - (2) Epoch 300ah Lithium batteries, Victron 3000W MultiPlus-II, Victron GX Touch 70, Victron Cerbo GX, Victron Smart Solar MPPT, Victron Smart Shunt, Victron Orion XS 1400 DC-DC charger, RV Soft Start. Zamp 90W suit case solar panel for 420W of solar.⚡️⚡️ North Carolina
jd1923 Posted May 23, 2025 Posted May 23, 2025 21 hours ago, Patriot said: The Starlink Mini is in sale right now… Oh man, I bought mine a month early! I hate when that happens, but love the product and service. Anybody reading, don’t have one? Buy now or be the lahooosier! 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Rolind Posted May 23, 2025 Posted May 23, 2025 On 5/21/2025 at 9:37 PM, John and Debbie said: How do you stream from your phone? I am not tech savvy. Any easy steps to take? We use this adapter and an hdmi cable. We plug into the furrion head unit. I usually have to play around with the settings on the head unit and the tv to make it work. Apple TV streaming service never works this way. The process is cumbersome, but we rarely watch tv in our trailer. I thought about using an Apple TV device to airplay to the tv, but I think both the phone and the Apple TV would need to be on the same WiFi to work and we often don’t have WiFi when camping. https://a.co/d/4M4fmmB 1 Robert and Cheryl, Louisville, KY, Legacy Elite II Hull #1390 Oliphino, TV F250 Tremor
CRM Posted May 23, 2025 Posted May 23, 2025 (edited) 2 hours ago, Rolind said: I thought about using an Apple TV device to airplay to the tv, but I think both the phone and the Apple TV would need to be on the same WiFi to work and we often don’t have WiFi when camping. https://a.co/d/4M4fmmB This is where the WiFiRanger or Cradlepoint routers if you have one, come in handy. We use ours as a local network to connect all our devices together even when there isn't WiFi available at a campground. Edited May 23, 2025 by CRM 2 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
