What type of torque tool is good for the electronic connections in our Oliver. Product name and link would be appreciated.
Our nuts on the inverter breaker came loose 2 years after I replaced the breaker. This caused intermittent issues and resulted in the flat cable ends becoming pitted. I sprayed the ends with 2 coats of a conductivity product. After it dried I installed cables and nuts, and applied Locktite Green per Jason E. I tightened with a wrench.
I would have felt a lot better if I knew they were tightened correctly.
Well, you're definitely going to need a inch pounds torque wrench, and you can probably get the torque specs off the breaker installation or spec sheet.
2010 Elite II Hull #45, the first LE2 sold.  2020 Toyota Tundra TRD Off Road 4WD 5.7 with 4.30 axle and tow package.
John, I would just go with hand tightening, but…
What would help is to purchase new split lock washers, nuts too if you like, correct size and good quality from a local hardware store (not Amazon).
The hardware parts on these breakers are cheap and weak. The stronger spring steel in good washers should hold tight. You can torque, even over-torque the cheap hardware and they will still loosen up. Give my idea a try! 😂
Bike torque wrench I use for electrical.
https://a.co/d/6xEek4l
IMG_4256.thumb.png.d59824a85d496c32b11558aaa6ef04a8.pngIMG_4260.thumb.jpeg.3400bae8295b7312dbdffc46bc10bf9a.jpeg
you probably have any sockets you  need already.
if not here’s one in in-lb with sockets:
https://amzn.to/3G4ja5W
Craig
