Some ford trucks are missing a brake pedal spring, which can result in total loss of braking. Here is the recall information:
https://www.nhtsa.gov/?nhtsaId=25V401000
Summary
Ford Motor Company (Ford) is recalling certain 2025 F-550 SD, F-450 SD, F-350 SD, and F-250 SD vehicles. The brake booster pushrod retaining spring may not have been installed, which can allow the pushrod to disconnect from the brake pedal and cause a sudden loss of brake function.
You can search to see if your vehicle is effected (or if any vehicle has a pending recall) here:
https://www.nhtsa.gov/recalls
Steve - Northern Ohio, USA
Facebook - Instagram
This was reportedly the result of allowing a trainee to do assembly work while unsupervised!🤨
The problem was actually discovered by a seasoned employee further down the line.  They have a record of which trucks he worked on.
Edited by Ollie-Haus
States Visited Map
Former trainee…😄
Edited by Patriot
  • Haha 2
North Carolina 🇺🇸
