7 hours ago, jd1923 said:
If you replaced your wet-bolts, purchased the HD shackles and wet-bolt setup from Alcan, the Zerk thread size is 1/4"-28. I purchased this 50-pack, zinc-plated steel like OEM (could not easily find brass or SS in this size).
For future reference:
Edited by Ronbrink
$24 for qty 10, too bad it's not for the dozen (qty 12) required, so total with Grainger would be $48 plus shipping. I'll stick with $10 and Prime shipping for qty 50 zinc-plated steel!
First 2 Oliver friends we run into this winter in the Arizona desert... Just ask me and I'll have a dozen free 45-degree Zerks for you! 😎 (for those with Alcan wet-bolts)
I'm going without the rubber caps this time. The ones I took off seemed to be dirt magnets! I'll do what I've always done, use a brass brush and paper towel, clean them before lubing! I've never seen Zerks capped on a car or truck suspension.
I may follow suit John :)
ALAZARAKCACOFLGAIDILINIAKSKYLAMEMDMAMIMNMS
On 10/3/2025 at 7:05 PM, jd1923 said:
If you replaced your wet-bolts, purchased the HD shackles and wet-bolt setup from Alcan, the Zerk thread size is 1/4"-28. I purchased this 50-pack, zinc-plated steel like OEM (could not easily find brass or SS in this size). Nice longer threads on this product:
https://www.amazon.com/dp/B0DQBPTK3Y?ref=fed_asin_title&th=1
Update: I installed these grease fittings before our trip, but had not greased them since that was just done. Today, I got under the trailer to re-torque the new suspension and then to grease the wet-bolts after our 1000-mile trip. These aftermarket "Zerks" must be of poor quality! When greasing with a power grease gun, using the LockNLube fitting, grease was leaking at the entry point. These must be substandard in size or shape as the LockNLube generally connects tight without leaking. Amazon is getting another return! Good thing it's only a 10-min job to change them out!
So, back to the drawing board on these. Thinking I will order two Dorman 852-703 (6-packs). Hopefully the Dorman brand is still good quality today. They market them as "Automotive Grade." These are zinc-plated. I would be leery of stainless steel fittings as they will certainly be off-brand (zinc being what’s standard in SAE automotive hardware).
BTW, after torquing at 30, 60, 240 and 1020 miles, the last time tightening required was negligible! I'll check them again next summer after several winter and spring outings. All done, all good! 😎
Edited by jd1923
  • 2 months later...
I have been fascinated by what I've read on this forum regarding the D52 3500# axles with 4 leaf Dexter springs.......I just looked at my new purchase....tag you're it.
Sounds like this upgrade is inevitable, any suggestions on timing, partial upgrade, spares to carry in the meantime? I'm interested in your thoughts.  Sam
2025 Oliver E2 Hull # 1590 - 2025 F-150 Lariat 4WD 5' Bed PowerBoost 7.2 kW
I upgraded to the beefier ALCAN springs and  larger axles last year.  That means I drove about 100K miles over 9 years with the smaller 3500lb axles and Dexter 4 leafs.  That mileage includes some rough roads/off roads.  I’d say you don’t need to rush to upgrade, do it when the timing/budget allows.  My only exception might be if you are planning a trip to Alaska, the upgraded suspension might be a good idea.  Mike
Mike,
Thanks - makes sense, stepped approach. Your history and that of others means I can plan this upgrade for awhile in the future. Periodic inspection of the leaf springs is now on my pre and post trip inspection list.
I did find out (from another thread on this forum and the Dexter catalog) the D52 on my axle indicated 5200# capacity. The 6 lug hub configuration along with the 5 bolt backing plate confirms this as well......my upgrade just became quite simple. Sam
Yes, D52 on the axle label means 5200 LB axles, the 5-bolt brake backing plate, 12" brakes, etc. Newer Olivers have D52 axles. Yours likely has 1750 LB springs and if so your label should say CAPACITY: 3500 LBS. My label is on custom ordered axles where OEM our trailer had 4-bolt D35 axles. Since Dexter new from Alcan that 2750 LB springs would be installed, my axles are labeled CAPACITY: 5200 LBS. Your upgrade should be leaf springs only when you want your Oliver towing more firmly down the highway!
