Tony and Rhonda Posted September 17 Posted September 17 I'm trying to fish the data cable for the Victron BMV-712 from the display beside the Zamp controller down to the street side under-bed area. This is the street side space between the Zamp install/rear window and the pantry/battery box. I've been trying to follow the solar wires but there seems to be an obstruction across this space. Has anyone successfully fished a wire through this area? If not, any suggestions where to run the cable? Thanks,Tony New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (still with original engine) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Ray Kimsey Posted September 17 Posted September 17 (edited) I tried also. There does appear to be an obstruction. I ran the cable along the back of the cabinet to the rear of the trailer and then ran it down and under the basement and over to where I installed the cerbo gx. Was very easy to let it pass down in the rear. Edited September 17 by Ray Kimsey 1 2019 Ram 1500 5.7L V8, 3.92 axle ratio - 2020 LEll - Hull676
Ray Kimsey Posted September 17 Posted September 17 (edited) 10 minutes ago, Ray Kimsey said: I tried also. There does appear to be an obstruction. I ran the cable along the back of the cabinet to the rear of the trailer and then ran it down and under the basement and over to where I installed the cerbo gx. Was very easy to let it pass down in the rear. When I did this I had to purchase a 16' extension for the HDMI and USB cables (Amazon) which was just long enough for my needs. Edited September 17 by Ray Kimsey 1 2019 Ram 1500 5.7L V8, 3.92 axle ratio - 2020 LEll - Hull676
Moderator+ ScubaRx Posted September 17 Moderator+ Posted September 17 The rear port side corner is the only top to bottom wire chase that exists. 1 2 Steve, Tali and our dog Rocky plus our beloved dogs Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4
Tony and Rhonda Posted September 17 Author Posted September 17 Thanks for the suggestion @Ray Kimsey. I'll go out and give it a try. The VIctron came with a long data cable so I don't think I'll need a longer one but I'll see. Thanks @ScubaRx. That's good to know! Tony New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (still with original engine) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Tony and Rhonda Posted September 17 Author Posted September 17 I was finally able to run the cable. I had to fish from the bottom up, just couldn't get past something between the hulls working from the top. Thanks for the help. Tony 1 New to us 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (still with original engine) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
Moderators mossemi Posted September 18 Moderators Posted September 18 @ScubaRx forgot to mention his trick about leaving a piece of string trimmer line in the rear port side corner for future wire pulls! Mossey 4 Mike and Krunch Lutz, FL 2017 LEII #193 “the dog house”
