I'm trying to fish the data cable for the Victron BMV-712 from the display beside the Zamp controller down to the street side under-bed area. This is the street side space between the Zamp install/rear window and the pantry/battery box. I've been trying to follow the solar wires but there seems to be an obstruction across this space.
Has anyone successfully fished a wire through this area?
If not, any suggestions where to run the cable?
Thanks,Tony
New to us 2017 Legacy Elite II Hull #251 (with updates)
TV:  2023 Tundra Double Cab 4x4 TRD Sport (still with original engine)
I tried also. There does appear to be an obstruction. I ran the cable along the back of the cabinet to the rear of the trailer and then ran it down and under the basement and over to where I installed the cerbo gx. Was very easy to let it pass down in the rear.
Edited by Ray Kimsey
2019 Ram 1500 5.7L V8, 3.92 axle ratio - 2020 LEll - Hull676
When I did this I had to purchase a 16' extension for the HDMI and USB cables  (Amazon) which was just long enough for my needs.
The rear port side corner is the only top to bottom wire chase that exists.
Thanks for the suggestion @Ray Kimsey. I'll go out and give it a try. The VIctron came with a long data cable so I don't think I'll need a longer one but I'll see.
Thanks @ScubaRx. That's good to know!
Tony
I was finally able to run the cable. I had to fish from the bottom up, just couldn't get past something between the hulls working from the top.
Thanks for the help.
Tony
@ScubaRx forgot to mention his trick about leaving a piece of string trimmer line in the rear port side corner for future wire pulls!
