CRM Posted October 18 Posted October 18 10 minutes ago, Snackchaser said: Although fiberglass is not conductive, the frame, bumpers and hitch are! Under the right conditions, even the metal outside of appliances inside the camper could become energized. This could happen even if plugged into a GFCI outlet since GFCI's don't monitor for voltage on the ground. 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Ronbrink Posted October 19 Posted October 19 (edited) On 10/16/2025 at 9:12 PM, CRM said: A bootleg ground at the pedestal with an internal fault in the RV could do it. Not sure if the EMS would even see this as a fault. All the more reason to test the pedestal’s 30/50A receptacle before plugging in the AC power cord! I have the Progressive Industries 30A tester, which detects wiring faults; to include open ground, open neutral, open hot, hot/neutral reversed and hot/ground reversed. My pedestal surge protector also serves as a circuit analyzer and then a Hughes Autoformer staged as power first enters the Oliver. Edited October 19 by Ronbrink Ron and Brooxie | Clear Lake (Houston), Texas 2020 OLEll, Twin, 579: No installed solar, dual 30# propane tanks w/GasStop safety devices, Renogy 40A DC-DC charger, 460Ah LFP battery bank/Victron SmartShunt, auxiliary Cerbo-S GX/Victron 30A Blue Smart IP22 Charger combo, interior mounted Hughes Autoformer, twin independent sliding Lagun mount tables, extended dinette table and pantry landing, tongue-mounted hoist, Beech Lane refrigerator Ventilation/Evaporate Coil fans, metal valve stems with TST cap sensors and signal repeater, Waste Master sewer hose management system, Dreiha Atmos 4.4 A/C upgrade/Ceilo Breez Max thermostat, FlagpoleBuddy Starlink Mini suction mount kit. 2019 GMC Savana 2500 Cargo Work Van: Explorer Limited SE, Low-Top 7 Passenger van conversion, 6.0L V8 Vortec, 6-Speed Automatic, RWD; Air-Lift LoadLifter air suspension/WirelessAir compressor; Bilstein B6 4600 Series shocks; metal valve stems for TST tire pressure monitoring system; Buyers Products cargo containment boxes/DC Cargo securement system; rear bumper DC-DC Anderson power cable outlet; 100Ah 12V portable power station/Dometic CFX 75L Dual Zone cooler; front 2” receiver hitch/QuikrStuff Mach2 double bike rack; Mechman 320A high output alternator; Starlink Mini/Veritas Vans magnetic mount.
CRM Posted October 19 Posted October 19 47 minutes ago, Ronbrink said: All the more reason to test the pedestal’s 30/50A receptacle before plugging in the AC power cord! I have the Progressive Industries 30A tester, which detects wiring faults; to include open ground, open neutral, open hot, hot/neutral reversed and hot/ground reversed. My pedestal surge protector also serves as a circuit analyzer and then a Hughes Autoformer staged as power first enters the Oliver. I have the same basic setup, though hardwired inside. One of the things it can't test for is a bootleg neutral/ground at the pedestal which is a wiring fault that can cause a lot of troubles if you have a fault inside the camper. Even worse is if you have a bootleg ground AND reverse polarity at the pedestal. This wiring fault will energize anything metal in the camper that is internally grounded with 120v and it can't be picked up by any EMS or three light testers. Using a non-contact voltage tester on the frame is the only easy way (other than getting shocked) that you would know... 1 1 2010 Elite II Hull #45, the first LE2 sold. 2020 Toyota Tundra TRD Off Road 4WD 5.7 with 38 gallon tank, 4.30 axle and tow package.
Geronimo John Posted October 29 Posted October 29 (edited) On 10/17/2025 at 8:57 AM, CRM said: This condition is dangerous because it can result in a "hot skin" on the RV, meaning the metal frame and any connected appliances become energized at 120 volts. On 10/18/2025 at 6:14 AM, Snackchaser said: Although fiberglass is not conductive, the frame, bumpers and hitch are! I agree with both of the above. We are incontact with the bumpers and frame typically at the dump station and when hitching up. Maybe a few times during our stop. BUT the steps are the one that could get most of us.... many times a day. Not just casually, but when one foot is on the step and the other contacts the earth. GJ That said, I'll not be changing our PI Power Mgt System any time soon. Two other things that I do keep top of mind when working electricl are: Situations where "The Step Potential" could be in play Forgetting to keep one hand in my pocket when working a open hot panel or device. Edited October 29 by Geronimo John 2 TV: 2019 F-150 SuperCrew Lariat, 3.5L EcoBoost, 10 Speed Trans, Max Tow, FX-4, Rear Locker OLLIE: 2018 OE2 Hull 342, Twin Bed. OLLIE DIY’s: Timken Bearings, BB LiFePO4's, Victron 712 Smart, 350 Amp Master Switch, Houghton 3400, Victron Orion DC - DC, 3000-Watt Renogy Inverter, P.D. 60-amp Converter, Frig Dual Exhaust Fans, Kitchen Drawer Straps. Front Wardrobe Shelves, Snuggle Shelf. TV DIY’s: 2 5/16" Anderson System, Nitto recon’s, Firestone Rear Air Bags, Bilstein 5100’s, Mud Flaps & Weather Tech all, installed Ham Radio (WH6JPR).
