Steve Gorman Posted October 16, 2025 Posted October 16, 2025 Everytime I pull out my faucet to shower. I lose my water pressure. Is this normal? How can I fix this?
Moderators topgun2 Posted October 16, 2025 Moderators Posted October 16, 2025 Steve - Do you just lose pressure at the head of the faucet or does the loss of pressure also effect the kitchen? Do you know how far you pull the faucet out before it starts effecting the pressure? Bill 1 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC
Moderators Mike and Carol Posted October 16, 2025 Moderators Posted October 16, 2025 I would remove the insert under the sink and look at what the hose is doing when you pull it out. It must be kinking somehow. The insert is easy to remove and goes back on just as easy. You’ll just need to recaulk. Mike 1 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Steve and MA Posted October 16, 2025 Posted October 16, 2025 The hose on ours pinches easily when in use, restricting flow. The hose is quite soft, so it doesn't take a sharp bend for it to collapse. Before taking off the panel insert to check under the sink, make sure the hose isn't slightly pinched when it's pulled out. It took us a few uses to figure this out. 1 Steve & Mary Allyn San Antonio, TX 2022 LE II Hull #969 "Un Œuf", 2021 MB Sprinter 3500 "Polly", 2008 Pleasure-Way Excel TS "Val", 1975 GMC Glenbrook "Whoosh"
Steve Gorman Posted October 16, 2025 Author Posted October 16, 2025 Thank you for your responses. I was told that this is a outstanding to get feedback on what you need to do. I'm glad that I bought a ollie 4
