4 hours ago, jd1923 said:
A 15 or 20A ATS can be used with an inverter when the inverter does not have a built-in ATS. It is used to switch between shore power and inverted power for a 15 or 20A circuit. Our Victron has a built-in ATS but the 2KW Xantrex inverter OTT originally installed did not (see pic, ATS in middle). An external 15A ATS was added to switch all circuits except A/C to use shore power when present or inverted power when not. Some Oliver owners added the 20 KISEA ATS to add switching for the A/C circuit.
JD:  Your concise description is excellent.  Thanks for clarifying.
The picture below shows the KISEA I installed for literally a few days before I decided on the Victron upgrade.
If you decide you don't need that spare part KISEA for your Victron system, I'll gladly purchase it from you next summer!  Would be a really good spare part for my "Older Design" system.
John, mine had an intermittent issue and the reseller refunded upon return.
  • Sad 1
