JuniorBirdMan Posted November 17, 2015 Share Posted November 17, 2015 200 watts of solar power + water purification system = living off grid indefinitely! Aubrey and the two wingmen, Woodstock & Rascal Oliver #032, "El Huevito" Ford F-150 4x4 Link to comment Share on other sites More sharing options...
trumpetguy Posted November 17, 2015 Share Posted November 17, 2015 That sense of independence must feel great. What do you use for water purification? I have seen small distillers on Gone With the Wynns, and the Seychelle filters are good. We have a Big Burkee at home but it is too big for the Ollie. A small system that draws little power would be great. Current 2007 Airstream Classic Limited 31 2015 Oliver Legacy Elite II (Sold) 2016 Ram 2500 HD 6.7i Cummins turbo diesel Link to comment Share on other sites More sharing options...
JuniorBirdMan Posted November 17, 2015 Author Share Posted November 17, 2015 I use a triple canister system with Sterilight UV from the RV Water Filter Store: Additionally, I add Purogene (chlorine dioxide, available from the same people) to the fresh water tank. It prevents the growth of biofilm and is certified by the EPA to keep drinking water safe for up to 5 years. Last winter I was on a lengthy caravan to Mexico and Belize where water is a real issue. While most of the participants had to continuously struggle with 5-gallon purified water jugs, a couple of us used this system. A 45-gallon water bladder (Camping World) and a transfer pump to force the water from the bladder through the canisters (it will NOT gravity feed thru the canisters) and we had safe, pure water the entire trip. We even sucked water out of a nearby lake and had no problems at all. I keep the system in my truck (too large to fit in my Ollie) and use it if I need to get water from mountain lakes/streams. If city water is available I use only the Purogene. Aubrey and the two wingmen, Woodstock & Rascal Oliver #032, "El Huevito" Ford F-150 4x4 Link to comment Share on other sites More sharing options...
routlaw Posted November 17, 2015 Share Posted November 17, 2015 We have a whole house water purification system as well and have often wanted something similar for our Oliver, however the taste of water from the holding tanks with or without purification is… shall we say less than desirable. Not sure what it is about these holding tanks that impart such an ugly taste when by comparison you can buy purified water all over the country in gallon to 2.5 gal plastic containers that do not impart this nasty taste. This is not something unique to Oliver all RV's have this problem. So on our last trip we just broke down and bought gal jugs of water, and will probably continue to do so. This system looks promising though I'm not sure I would want to use the chlorine supplement. So can you run the pump from your 12 volt system? Thanks Legacy Elite II #70 Link to comment Share on other sites More sharing options...
JuniorBirdMan Posted November 17, 2015 Author Share Posted November 17, 2015 I use the Wayne PC-2 pump (AC) since my truck has a handy built-in inverter. The Wayne PC-1 (DC) is also available. Aubrey and the two wingmen, Woodstock & Rascal Oliver #032, "El Huevito" Ford F-150 4x4 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted November 18, 2015 Moderators Share Posted November 18, 2015 Aubrey, Your installation looks awesome. Love the solar. I like the idea of your water purification system, too. Thanks for the photos and info. Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
JuniorBirdMan Posted November 23, 2015 Author Share Posted November 23, 2015 I've been asked how I secured the solar panels to the roof. I didn't want bolts protruding into the cabin from above, but I also didn't trust the 3M VHB tape alone to hold the mounting brackets in place.The answer: rubber wellnuts, also called rubber expansion nuts, with brass inserts. They fit nicely between the inner and outer hulls. They're available at home improvement and hardware stores including Lowe's and Home Depot. They'd also be useful for bolting things to the fiberglass walls where the backside isn't accessible. Aubrey and the two wingmen, Woodstock & Rascal Oliver #032, "El Huevito" Ford F-150 4x4 Link to comment Share on other sites More sharing options...
Moderator+ ScubaRx Posted December 23, 2015 Moderator+ Share Posted December 23, 2015 Said wellnuts would have come in handy a few months ago when I drilled a hole in the top of my fresh water tank. Well, of course, it was an accident. What, do you think I meant to do that????? Where were you and this information when I needed it? Gee, thanks Aubrey. Nice looking solar setup BTW. Steve, Tali and our dog Rocky plus our beloved Storm, Lucy, Maggie and Reacher (all waiting at the Rainbow Bridge) 2008 Legacy Elite I - Outlaw Oliver, Hull #026 | 2014 Legacy Elite II - Outlaw Oliver, Hull #050 | 2022 Silverado High Country 3500HD SRW Diesel 4x4 Link to comment Share on other sites More sharing options...
JuniorBirdMan Posted December 24, 2015 Author Share Posted December 24, 2015 You could always claim the hole was intentional so the water supply could "breathe", much like a fine wine. Come to think of it, filling the tank with wine might not be a bad idea! Aubrey and the two wingmen, Woodstock & Rascal Oliver #032, "El Huevito" Ford F-150 4x4 Link to comment Share on other sites More sharing options...
