Olive2Roam Posted 5 hours ago Posted 5 hours ago (edited) Does anybody have a supplier for the weatherstripping that goes around the windows in a 2024? That stuff is nearly impossible to get clean and I would just like to replace it all. It comes from Lippert, but Oliver hasn’t been able to get them to provide any replacement rolls of the stuff. Appreciate your thoughts. Bob Edited 5 hours ago by Olive2Roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
Dean and Mary Posted 4 hours ago Posted 4 hours ago Steele Rubber Products sells window molding weather strip (part # 70-4500-257), and it worked perfectly on my 2022 Oliver Elite II. I learned about it from another forum member who recommended it in a different thread. Another option is: Pelland Enterprises - (part # H109-376). I ordered both products to compare, but have yet to receive the Pelland product. TV: 2019 F-160 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC – DC charger, Victron Energy Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
Olive2Roam Posted 4 hours ago Author Posted 4 hours ago (edited) 28 minutes ago, Dean and Mary said: Steele Rubber Products sells window molding weather strip (part # 70-4500-257), and it worked perfectly on my 2022 Oliver Elite II. I learned about it from another forum member who recommended it in a different thread. Another option is: Pelland Enterprises - (part # H109-376). I ordered both products to compare, but have yet to receive the Pelland product. That’s great information. Thanks for sharing. I will check out the Steele product. I would be curious about the Pelland as well. Let us know how that works out. Thanks again! Edited 4 hours ago by Olive2Roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
jd1923 Posted 2 hours ago Posted 2 hours ago (edited) 3 hours ago, Olive2Roam said: Does anybody have a supplier for the weatherstripping that goes around the windows in a 2024? Not certain re 2024, but this is what I purchased for the rubber surround on the window half that opens, as pictured. https://www.pellandent.com/Half-Inch-Glass-Vinyl-Seal Edited 2 hours ago by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Olive2Roam Posted 1 hour ago Author Posted 1 hour ago (edited) 51 minutes ago, jd1923 said: Not certain re 2024, but this is what I purchased for the rubber surround on the window half that opens, as pictured. https://www.pellandent.com/Half-Inch-Glass-Vinyl-Seal Looks like it would work in the 2024. Did they have white available? I didn't see a color sector. Edited 1 hour ago by Olive2Roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
jd1923 Posted 58 minutes ago Posted 58 minutes ago (edited) 37 minutes ago, Olive2Roam said: Looks like it would work in the 2024. Did they have white available? I didn't see a color sector. Bob, I believe Mike was the first to switch to BLACK and he convinced me a couple years ago when I replaced ours. See what my white ones looked like! And on your hull, only 2 years old, they need replacing? The windows look black, the thin rubber on the stationery window is black and over time the black will still look new. Mold stains the white and you cannot see it on black. They may not supply white anymore due to this issue. Actually, the window frames look more balanced left to right with the black moldings (pic1). BTW, to be sure for your hull, remove one edge to see if the profile of the rubber looks identical (pic2). Edited 49 minutes ago by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Dean and Mary Posted 55 minutes ago Posted 55 minutes ago Oliver2Roam, I’ll let you know when the Pelland product arrives. After posting my first response, I called Pelland Enterprise and was told the window seal is still on backorder, but they expect it to ship in about 2–3 weeks. Dean TV: 2019 F-160 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC – DC charger, Victron Energy Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
jd1923 Posted 53 minutes ago Posted 53 minutes ago (edited) Dup post deleted. Edited 52 minutes ago by jd1923 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
