I'm beginning to look more seriously at what my next set of OE2 tires should be.  Spent lots of time on the "Tire Finder" and Road and Track only to be disappointed.  Their trailer tire selection info was pretty limited.  Got to thinking further and recalled that a long time ago, a member indicated that he was using ribbed tires on his Oliver Trailer. So to the AI  rabbit hole I went.
I stated that I wanted a tire like my 2019 OTT OEM Michelin Defenders.  They have lasted 9 seasons and at 50,000 miles are in great shape with zero problems.  I added that it is important to me that they not toss rocks.  The results are outlined in the attachment under "Option One".
The more I thought about it, I decided to load up AI with my full wish list of attributes and fired it off for it to chew further.  The AI response to this list provided in the attachment under "Option 2".
The attachment is provided for your reading enjoyment and comment. What do you think about using ribbed tires on our OE2's?
But more importantly to plant the seed for interested owner's to modify the list with YOUR style of use and requirements.  Then to share them for us all to consider further.
OE2 TIRES RIBBED or LT.docx
Edited by Geronimo John
GJ vs AI, decisions, decisions!
Although I avoid gravel roads when possible, I sometimes end up on gravel during our travels.  And, my long driveway in rural Idaho is gravel.  So, for me, the ribbed tires make sense.  Thanks for sharing your research!
I was asked why I would tow our OE2 at 95 MPH.  Answer is I don't.  Then why ask AI to require at least this speed rating?  Good question.
WHY?  A tire's speed rating indicates how well a tire dissipates heat during prolonged high-speed driving.  I and many of our forum members cover lots of mils at posted speed limits.  Likewise a lot of us do so during the summer crossing hundred mile streaches of desert areas with temperatures over 100 degrees and high speeds as well. Hence I want tires that can "take the heat".  This is true for both my TV and Ollie tires.
RESULT?  Zero roadside tire issues in over 40 years.
HOW?  I always buy tires with a Load and Speed Ratings that are well above what is recommended for the average driver.
