Olive2Roam Posted yesterday at 02:01 PM Posted yesterday at 02:01 PM I know it's here somewhere but I can't seem to locate the sequence for shutting these down for storage. Does anyone have the order of shutdown/start up for these components for storage? Thanks! https://www.instagram.com/campbells_olive2roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
jd1923 Posted yesterday at 05:38 PM Posted yesterday at 05:38 PM 3 hours ago, Olive2Roam said: I know it's here somewhere but I can't seem to locate the sequence for shutting these down for storage. Does anyone have the order of shutdown/start up for these components for storage? Thanks! Throw the switch or breaker on your solar first since it’s the only item that produces power. Store LiFePO4 batteries at 50-60 SOC%. You may need your inverter on to run SOC down. Then switch inverter off, or it will go dead as soon as both shore power and batteries are disconnected. Finally throw battery switch if you have one or disconnect main ground. 1 Chris & John in Prescott, AZ | 2016 EII #113 | '01 Ram 2500 Cummins!
Olive2Roam Posted 23 hours ago Author Posted 23 hours ago Ah yes, and reverse the order on startup. Thanks JD! 1 https://www.instagram.com/campbells_olive2roam 2024 Legacy Elite Platinum, Hull #1465 2024 Nissan Pathfinder, Rock Creek Edition Lithium Batteries (260AH), 240 Watt Solar with Charge Controller, and a 2000 Watt Pro Inverter. Victron Orion XS 50A DC-DC Battery Charger
Dean and Mary Posted 20 hours ago Posted 20 hours ago 3 hours ago, jd1923 said: Throw the switch or breaker on your solar first since it’s the only item that produces power. Store LiFePO4 batteries at 50-60 SOC%. You may need your inverter on to run SOC down. Then switch inverter off, or it will go dead as soon as both shore power and batteries are disconnected. Finally throw battery switch if you have one or disconnect main ground. Good advice above. In addition, if you have lithium batteries with a built-in Battery Management System (BMS), consider powering the batteries off (via the built in battery power switch) as well as throwing the physical battery disconnect switch. TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package. Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires. After market: Victron MultiPlus-II 12/4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC-DC charger 12/12V 50A 700W, Cerbo GX MK2 with GX Touch 70 Display. Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
