Oliver Basement Repair
While searching the forums, I did not find much information regarding basement damage and/or repairs, so I thought I would document my experience.
We purchased our 2022 Oliver used, and the rear basement compartment had suffered significant damage. The back/end panel had broken loose, and the floor was cracked where the three floor sections join together. I'm not sure what the previous owner stored back there to cause that level of damage, but after about 30 hours of work, the compartment is now stronger than when it left the factory.
Most of the time involved was due to the difficult access. Working through the small openings requires a great deal of patience and, at times, the flexibility of a contortionist.
Rear of Basement Panel
On our trailer, the rear/end vertical panel was secured by a single strip of Starboard attached only to the lower portion of the panel and fastened to the floor with just two screws. any pressure on the top of the panel will break the small strip holding it in place and the panel will fall down into the space behind the heater.
To strengthen the installation, I fabricated support brackets from aluminum angle. This allowed me to secure both the bottom and the top of the rear panel. The upper bracket is bonded to the fiberglass using 3M VHB tape and then mechanically fastened to the rear panel. The lower bracket is screwed to both the floor and the rear panel.
Having the interior access door was a tremendous advantage. Even with that access, there was only enough room for my head and one arm to fit into the compartment while working.
Anybody found themselves in this position while working on/in the basement? 🙂
Floor Reinforcement
The basement floor is constructed from three separate pieces, and the original support for the floor consisted of a Starboard strip secured with only three screws. If enough weight is placed in the center of the compartment, the floor support can crack, as ours did. The spacing of the three screws was to far apart. A fourth screw might have saved it from breaking.
Disassembly took longer than expected because the flexible rear panel had to be removed before the floor sections could be extracted. Once removed, I replaced the support arrangement with a much more substantial reinforcement piece with an extended piece of angle iron and then secured it with six screws.
I also added a piece of high-density rubber between the floor and the frame beneath the previously unsupported area. The result is a dramatically stronger floor. I can now stand on it and bounce up and down without any concern.
Improved Floor Covering
After completing the structural repairs, I added a new floor covering made from an outdoor mat material. It has a rubber backing and a textured surface that provides good traction while still allowing cargo to slide when needed.
The new mat sits on top of the factory rubber flooring and can be easily removed for cleaning. My Action Packer storage box now slides much more smoothly while remaining secure during travel. An added benefit is that the mat creates a seamless transition across the joint between the two sections of factory rubber covering.
Side Panel Support
While working in the compartment, I noticed that left side panel lacked support along its upper edge. I used additional aluminum angle to fabricate a support bracket for that panel as well. The bracket is fastened to the vertical panel and bonded to the upper fiberglass surface with 3M VHB tape. This modification significantly stiffened the panel and should help prevent future damage. Below is the side panel bracket installed on the backside of the basement panel. The plastic in the photo will be for a future cable chase for my 12 volt upgrade.
____________________
Below are two photos of the finished product.
Edited by Dean and Mary
Clarification
TV: 2019 F-150 Super Crew Lariat, 3.5L EcoBoost, 10 Speed Transmission, Max Tow and Offroad package.
Oliver: 2022 – Hull 953, Twin Bed, with Lithium Platinum Package (640ah Lithionics lithium batteries), Outdoor Pro Package, 16” wheels, D52 axles, 5-leaf Alcan Spring package, Bulldog HD Shock Absorbers, 2 5/16 Bulldog coupler and LT tires.
After market: Victron MultiPlus-II 12/4000, Two Victron 100/50 MPPT Solar Charge Controllers, Victron IP65 500A/50mV SmartShunt, Victron Lynx Distributor, Orion DC-DC charger 12/12V 50A 700W, Cerbo GX MK2 with GX Touch 70 Display.
Misc: Custom Wood Accessories by Foybles. Seabiscuit Metal Designs front storage box and moose rack.
Here is a before photo that I should have included above. In addition to showing the back panel pushed outward, it also highlights the rather sloppy "12-volt upgrade" performed by the shop hired by the previous owner.
There is quite a bit more to the electric story, along with additional photos documenting the wiring and installation issues, in a future thread. Suffice it to say that correcting and redesigning parts of that upgrade has become one of my ongoing projects. In short, all of the upgrade wiring was pulled along with some factory stuff.
Clarification
I was doing some work in the basement in 2020 and found the back wall was loose. The sawn strip of what I think is PVC board had broken where a screw had been placed. I replaced the small strip of PVC (?) with a piece of PVC angle that I shaped by heating with a heat gun and bending while holding one side against a flat surface. This repair has held up well.
Bill 2018 hull 313
Bill and Martha
2019 Chevrolet 2500HD Duramax
Interestingly, that was the only support piece in my basement that survived intact. I believe the material is King StarBoard, a material similar to High-Density polyethylene (HDPE). It is much lighter, and not as strong as (HDPE). Others may want to weigh in if I have that wrong.
The two support pieces that broke in my camper looked very similar to the one in your photo, with both failures occurring at the screw hole. Your solution is well thought out, and the installation looks good.
Below is a photo of the broken original floor support next to the replacement I made. Yes, it's oak. I chose that route before I became immersed in fabricating components for my 12-volt upgrade, and at the time I didn't have any HDPE material on hand to work with. Fortunately, this support sits a few inches above the floor and has a protective finish applied. I'm confident it will hold up well, and once the floor is reinstalled, it will be completely hidden from view. The aluminum piece adds support to prevent scissoring of the other two pieces of floor.
Clarification
Our hull does not have a "back panel." Is this true for other 2016 owners? Perhaps there was one which got damaged, removed by a prior owner.
There are front panels and flooring made of that "light" version of HDPE. In the picture, I have the flooring removed from the right side. It is fully floored, but the back is wide open showing the plumbing, wiring and Reflectix insulation.
Notice in the rear both Fresh and City water lines show backflow check-valves and flow restrictors (see pic). If you compare the water lines to Dean's picture above, his are by the streetside opening (easier for maintenance) vs. center rear. I can't tell if Dean's water lines have both. The OTT schematics only show check valves, not flow restrictors.
We don't have the basement opening from the cabin, just the one exterior opening where the outdoor shower and waste valves are also located. I believe I can just barely get my upper body in there but must have somebody strong on hand to pull me out by the legs when I get stuck! 🤣 We call that opening and the rear storage area "the trunk!"
The DIY work displayed on our Forum generally illustrates excellent craftsmanship vs. "sloppy" shop work and much of it is to correct past installations, OEM and aftermarket. You can see the high caliber of work in Dean's and Bill's efforts on this one thread alone! I've read every post on our forum over the last 3 1/2 years, starting with all the good work of John E Davies, who retired from Ollie-land 3 years ago. It is a blessing that we have this platform to exchange ideas and upgrade our travel trailers! 😎
Edited by jd1923
Here is another photo of the water lines for reference. Please ignore all of the wiring hanging down in the photo. That wiring was part of the previous owner's "upgrade" and has since been completely removed.
