Hi all, the brass handle for the waterline turnoff fell off.  I used an endoscope and wasn't successful in finding it.  Oliver parts recommended an Amazon three way waterline valve that has the brass handle.  It's currently in the normal configuration.   I need to shut off water to the water heater.  When I put the handle on, do I turn to the left or right one quarter turn.
Thanks, John
Can't tell from your photos but if the valve has a "stump" sticking up and if you can access the stump with plyers, turning it 90 degrees away from the perpendicular water line should close the valve. If there is no stump you could try needle nose plyers to grab whatever the brass handle attached to.
I think you can test to make sure it's closed by running water into the trailer line. Drain the water heater by moving the yellow latch down and removing the filter/antifreeze filter. Leave the water heater's yellow latch down with the filter/antifreeze filter removed. Turn on the water. If the valve is closed, water should not flow out.
If you already have antifreeze in the water lines you will have to re-winterize the lines if you test the water heater like this.
Tony
2017 Legacy Elite II Hull #251 (with updates)
TV:  2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2)
I did not know the valve handle could fall off. Having a 90 degree valve in that location is easier to operate
Edited by dewdev
I had the valve handle fall off my water heater..  it was still in warrenty  they sent me the whole valve, it had to take the handle off it had a small set screw.. it was a PITA.. Because of the 6 gal  is so close to the inner wall on a Elite 1..  I would try what Tony said..Good luck.. p.s. why wouldn’t OTT sell you a valve?..
2022 Elite I  # 1179  |  2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
90 degrees CCW is CLOSED in 2018 hull number 313
I meant to respond to your question early this morning but got busy doing other stuff.
Edited by Townesw
Bill and Martha
2019 Chevrolet 2500HD Duramax
My valve handle fell off a couple of years ago.  Finally and with a mirror, I found it.  It cant go far!  I fished it out, put it back on, and tighten the hex screw nice and tight.  Havent had the problem since but i keep an eye on it.
