John and Debbie Posted Wednesday at 02:01 AM Posted Wednesday at 02:01 AM Hi all, the brass handle for the waterline turnoff fell off. I used an endoscope and wasn't successful in finding it. Oliver parts recommended an Amazon three way waterline valve that has the brass handle. It's currently in the normal configuration. I need to shut off water to the water heater. When I put the handle on, do I turn to the left or right one quarter turn. Thanks, John John and Debbie, Beaverton, Oregon, 2017 Ford Expedition EL 4x4 3.5 liter Ecoboost, with heavy duty tow package. Hull #1290, twin bed with Truma package (a/c, furnace, hot water heater with electric antifreeze option), lithium pro package, picked up November 7, 2022 Alcan 5 leaf springs and Bulldog shocks done May 20, 2025 in Grand Junction, Colorado
Tony and Rhonda Posted Wednesday at 02:40 PM Posted Wednesday at 02:40 PM Can't tell from your photos but if the valve has a "stump" sticking up and if you can access the stump with plyers, turning it 90 degrees away from the perpendicular water line should close the valve. If there is no stump you could try needle nose plyers to grab whatever the brass handle attached to. I think you can test to make sure it's closed by running water into the trailer line. Drain the water heater by moving the yellow latch down and removing the filter/antifreeze filter. Leave the water heater's yellow latch down with the filter/antifreeze filter removed. Turn on the water. If the valve is closed, water should not flow out. If you already have antifreeze in the water lines you will have to re-winterize the lines if you test the water heater like this. Tony 2 2017 Legacy Elite II Hull #251 (with updates) TV: 2023 Tundra Double Cab 4x4 TRD Sport (Now with Engine #2) Formerly 2004 Tundra with 2015 Four Wheel Camper Fleet
dewdev Posted Wednesday at 04:26 PM Posted Wednesday at 04:26 PM (edited) I did not know the valve handle could fall off. Having a 90 degree valve in that location is easier to operate Edited Wednesday at 04:31 PM by dewdev 1 Richard, Marianna and Annie (our minature poodle): 2018 Oliver Elite II, Twin Bed, Hull #354, new 3 - 130 aH Lithonics batteries (390 total) and Xantrex Freedom XC 3000 Pro Inverter in 2025 2027 RAM 1500 Rebel, 4 x 4; 5.7L Gas V8 Hemi; 3.92 rear axle; 4 corner air suspension Maine
Golfnut Posted Wednesday at 07:15 PM Posted Wednesday at 07:15 PM I had the valve handle fall off my water heater.. it was still in warrenty they sent me the whole valve, it had to take the handle off it had a small set screw.. it was a PITA.. Because of the 6 gal is so close to the inner wall on a Elite 1.. I would try what Tony said..Good luck.. p.s. why wouldn’t OTT sell you a valve?.. 2022 Elite I # 1179 | 2024 Tundra SR5 4x4 Crewmax. 5.5 ft. Bed. 3.31gears 10 spd.trans
Townesw Posted Wednesday at 08:13 PM Posted Wednesday at 08:13 PM (edited) 90 degrees CCW is CLOSED in 2018 hull number 313 I meant to respond to your question early this morning but got busy doing other stuff. Edited Thursday at 02:28 AM by Townesw 1 Bill and Martha 2018 LEII Hull 313 Original owners 3/14/2018 2019 Chevrolet 2500HD Duramax
FloraFauna Posted Thursday at 12:27 AM Posted Thursday at 12:27 AM My valve handle fell off a couple of years ago. Finally and with a mirror, I found it. It cant go far! I fished it out, put it back on, and tighten the hex screw nice and tight. Havent had the problem since but i keep an eye on it. 1 2023 Legacy Elite II - Twin Bed - Hull #1394 TV - 2020 Silverado 2500 Duramax 4x4
