Moderators bugeyedriver Posted April 25, 2017 Moderators Share Posted April 25, 2017 Checking Ollie systems prior to a long outing and discovered the nine year old vent fan would not turn on. Crud! Power to unit OK because hood went up and down and internal fuse is intact. Internet search found the fix. (Gotta love the Web for research) Release 5 screws that hold inner shroud and drop shroud. Unscrew fan blade and remove (take it inside for a good scrubbing in the kitchen sink) Find the thin silver plunger that tells when hood is down on the forward street side of unit and manually move up and down several times. Wipe down with cleaner and spray with electrical cleaner stuff in a can. Reverse removal process. Turn on fan. Smile! Avoid departure delay and $100/hour service fee. Life is Goooooood 6 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com Link to comment Share on other sites More sharing options...
Moderators topgun2 Posted April 26, 2017 Moderators Share Posted April 26, 2017 So, what were YOU doing while Bosker was completing all this work? Bill p.s. good job and I suspect you saved me some time on down the road - thanks! 2023 Ford F150 Lariat 3.5EB FX4 Max Towing, Max Payload, 2016 Oliver Elite II - Hull #117 "Twist" Near Asheville, NC Link to comment Share on other sites More sharing options...
John E Davies Posted April 26, 2017 Share Posted April 26, 2017 Thanks, that should go on an annual Spring checklist John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
MikeandGerri Posted April 26, 2017 Share Posted April 26, 2017 Great information to know and remember!! So simple too!! Thanks, Pete. Link to comment Share on other sites More sharing options...
Moderators bugeyedriver Posted April 26, 2017 Author Moderators Share Posted April 26, 2017 So, what were YOU doing while Bosker was completing all this work? . . . I was holding the little Whisker Britches up because his legs are too short. ;) 1 Pete & "Bosker". TV - '18 F150 Super-cab Fx4; RV - "The Wonder Egg"; '08 Elite, Hull Number 014. Travel blog of 1st 10 years' wanderings - http://www.peteandthewonderegg.blogspot.com Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted April 26, 2017 Moderators Share Posted April 26, 2017 You sure make that pup work hard for his kibble.... Good post. Thanks. On another note, we broke that little cover with the five screws this year. When I called Fantastic vent, I was connected to Dometic. Apparently, they bought the company that bought Fantastic several years ago. Still a somewhat separate division, but parts now need to be ordered from a distributor. Nothing stays the same... And Dometic has purchased a lot of the suppliers. Sherry 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
