9 minutes ago, John E Davies said:
general consensus among lithium manufacturers is do not keep them “topped off” all the time
This is my understanding also and this is how we care for our Battle Born batteries.
Kirk
10 minutes ago, John E Davies said:
I find this odd, the general consensus among lithium manufacturers is do not keep them “topped off” all the time. That is when most of the stress happens, cell equalization mainly. They all use the same sort of cells inside, only the management systems are propriatory .
https://olivertraveltrailers.com/forums/topic/6629-how-to-find-happiness-with-lifepo4-lithium-ion-batteries-solacity-article/
Even ebike batteries are like this, you should discharge them to about half charge and store them inside the house in the off season, for “best” long term life and performance. Whether doing that actually helps all that much for any specific unit is debatable….it is simply good practice.
Thank you, John
You find it odd, I find it frustrating!
I’am so perplexed!
One article someone posted earlier  said you don’t have to discharge battery to 50%.
Some say they stay plugged into shore power 24/7, others don’t.
Take batteries out. Leaves batteries in. Deplete battery to half, another says no need to deplete.
We are trying to do the right thing but finding the right answer is very trying.
2021 Dodge Ram 1500
2021 Oliver Elite ll
Hull #732
Michigan
@Katjo that is what we're going to do with ours this winter because we have the 315Ah batteries. Maybe it's ok because the internal heater is draining the batteries some before the converter and solar refill them? Don't know, but that's the mfg recommendation.
We are swaying on the side of doing the same and following the Lithionics guide.👍🏼
2021 Dodge Ram 1500
Hull #732
Michigan
We use a cover in the off-season at a storage lot.  I wrote about it here...
I leave the Renogy solar suitcase panel to keep the batteries charged.  Just covered it again for the winter.
It is a bit confusing to try and make sense of Lithionics recommendations.
If you store plugged in and you have a built in Lithionics heater all you do is shut down all CD loads. No need to do anything else and no potential warranty issues. We have heated storage with a 30 amp electric source, so no problem. However, our heater will  internal Lithionics heater will never turn on. We will not have that power drain. The situation is different than the one implied by Lithionics, however, technically it still full-fills their instructions.
It sounds like, if you have no internal heater or no source of electricity, then you have to follow Lithionics somewhat confusing and difficult instruction, keep a record of what you do, and still maintain the battery within a certain temperature range. If you have storage for over 3 month, it is below freezing and you don't have an internal battery heater or you don't have a source for electricity, then; I guess, you would have to remove the batteries, store them inside and then deal with their difficult instructions and keep a record for warranty validation.
These instructions and Lithionics recommendations do not give me confidence Lithionics Battery company.
Kirk
Kirk
That’s the way I’m understanding it as well.
Why won’t your internal heater not turn on?
2021 Dodge Ram 1500
Hull #732
Michigan
Sorry, that was a poorly written sentence. The heater will not turn on because our camper will be stored in a heated garage. That changes the situation given by Lithionics in the instruction.  Without the power draw from the heater, we would be keeping out batteries at 100% charge while stored. To my understanding, most Lithium battery companies do not recommend doing this.
Kirk
For what it's worth, Mike with Oliver Service confirmed today that Oliver trailers with the Lithium Pro Package (with external batter heating pad) can be left plugged into shore power during winter conditions, just like those with internal battery heaters.
See this thread:
We store our 2015 LE2 in an airplane hangar without electricity and heat since 2018, when not camping.
We use a master disconnect switch to disconnect the Battleborn battery while in storage.
Battleborn storage instructions:
Kirk
Oh, got it.
Yes, then you would have to remove batteries according to lithionics guide.
2021 Dodge Ram 1500
Hull #732
Michigan
