My hubby and I are trying to flush and clean out the black tank before winterizing.  We found the open valve under the table, turned it the way the pic in Oliver book shows, but water is NOT coming in and filling the tank.  What are we doing wrong??  And is there any video someone has posted of an Oliver?  We can't find anything on the forum.  No luck yet, anyway.  I have noticed when looking at old posts, the pics or video links are missing.  TIA!!  Rolayne and Rob Volpe, Hull #166
Just curious...did you hook the hose to the special black tank flush hookup? The flush system is not hooked to the rest of the plumbing. The hook up valve is on the driver side, outside, near the front. I also pump some antifreeze in that hose, though it doesn't take that much...
If you don't figure it out, an alternative is to step on the toilet flush valve and run a garden hose into the toilet.  It feeds directly into the black tank.
Did you ever figure this out? If you are indeed hooking up city water to the outside black tank connection and the manual valve is open under the front dinette area, then there is a blockage, or perhaps the check valve was installed backwards. The latter is unlikely, you would have seen signs of a sewage leak at the outside connection.
It’s a pretty simple system - unless there is user error, not much can go wrong.... Regardless, I think flushing the tank often would be smart, to prevent any issues with the spray nozzles getting plugged up, or the, uhmmm “deposits” hardening on the inside of the tank. You can always try the ice cube trick. Empty a big bag of ice down the toilet with a few gallons of fresh water and immediately tow the Ollie around for an hour or two. The ice will break up any hard stuff.
