Without listening I think it is probably normal. There is a little flexing to the floor with some associated noise. Mike
Ours is completly silent. I weigh 165, if you are heavier I think it could maybe creak a little, but popping or cracking noises would be a worry. That sounds like a break in the material. I think you should check with the factory on this one.... are there any physical signs, such as small cracks?
I doubt there’s a problem. A piece of fiberglass will squeak when flexed or moved while in contact with another piece. The shower pan is a separate piece fiberglass and is in contact with the interior hull. In addition, if there is any grit under the pan it may create a noise when stepped on.
The shower pan on our first Oliver cracked and I replaced it. The pan in the newer models are about 5 times thicker.
We had the same problem when we picked up our trailer in june.Jason removed shower pan and discovered that the foam on back was cut on angles with the center being the highest. He got a new pan from mfg side and installed it.Took about 4 hrs but it resolved the issue
We have hull number 178 and it has been in use for over 2 years.  Our shower floor has never made any noise or felt anything but solid when being stood or stepped on.
George and Gretchen
Gig Harbor, Wa.
Hull Number 178
  • 4 weeks later...
Thanks All for the replies and appreciate the direction.  We have an appointment at the factory for a number of fixes including the shower floor.
