I am in the process of modifying our standard floor plan to a modified twin bed floor plan (pictures to follow when complete).  I ordered the twin bed rails and installed them as directed by Oliver.
The bed rails were installed with nothing in between the rail and the hull and the rubber gasket, on the ledge the table sits on to make it into a bed, removed .  I used eight rivets on each rail and the rails seem very secure.
The problem is when you sit on the edge of the bed, there is significant gel coat to gel coat creaking.
I reached out to Oliver service and Jason suggested using double sided tape between the rail and the hull.  I have put a 3/4" strip on either side of the rivet holes, on the hull, and one on the vertical ledge surface.  I did not remove the backing from the tape and tried a test fit.  The creaking is significantly diminished but still present.  Is this normal?
Thank you for any insight anyone has.
Andrew
Andrew
It’s not normal for a factory model but this is the first I’ve heard of anyone doing a retrofit. My first thought is that the rivets might not be tight enough and maybe that’s where the creaking is coming from.
Andrew,
We had the same issue with the port side bed. Used thin gasket like material between the interior access door & interior hull over wheel well area under mattress and between the bed rail where it contacts the battery box enclosure under the pantry.
