Nan Posted February 14, 2020 Share Posted February 14, 2020 Is there any reason there would be a 10 amp fuse where a 7.5 amp fuse should be for the furnace? Thanks, Nan Link to comment Share on other sites More sharing options...
Mainiac Posted February 14, 2020 Share Posted February 14, 2020 A used unit? Could be it blew and somebody replaced it with what they had? Several of the fuses in my unit are different than the label on the door says they should be. Just haven't taken the time to go through the manuals and see what they should be. Guess as long as everything is working we would leave it alone. It is on our "To Do" list... Link to comment Share on other sites More sharing options...
Nan Posted February 14, 2020 Author Share Posted February 14, 2020 Yes, I bought it used. Thanks for the reply. Nan Link to comment Share on other sites More sharing options...
Mainiac Posted February 14, 2020 Share Posted February 14, 2020 How do you know it should be 7.5 amp? If you found that in a manual, then change it. A fuse kit at an auto parts store should have an assortment of fuses for your tool kit, or just the fuses you might need. If you don't have one get a kit with a fuse puller in it. Just makes life a little easier when laying on the floor with a small flashlight in your teeth. Good luck. 1 Link to comment Share on other sites More sharing options...
John E Davies Posted February 14, 2020 Share Posted February 14, 2020 (edited) 7.5 amp is maybe a little harder to find in a store.... I personally would not bother changing it, unless you already have a 7.5. The 10 will blow just as fast if there is a short circuit in the wire or furnace, which is its only purpose. Having a “too small” fuse would possibly be bad, since it could pop during normal operation. As an example, the factory was putting 1 amp fuses in the Natures Head toilet circuit (for the fan) and these would blow after a while. The NH factory specifies a 2.5 which does not pop. But it is hard to find, so I use a 3... John Davies Spokane WA Edited February 14, 2020 by John E Davies 1 SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
The Shackelfords Posted February 14, 2020 Share Posted February 14, 2020 2 minutes ago, John E Davies said: 7.5 amp is maybe a little harder to find in a store.... I personally would not bother changing it, unless you already have a 7.5. The 10 will blow just as fast if there is a short circuit in the wire or furnace, which is its only purpose. Having a “too small” fuse would possibly be bad, since it could pop during normal operation. John Davies Spokane WA I agree, a 10 amp fuse is way easier to find in convenient bulk kits, and will blow just about as safely as the 7.5 amp fuse. I would not worry to much about that difference. 1 Link to comment Share on other sites More sharing options...
Nan Posted February 14, 2020 Author Share Posted February 14, 2020 Thanks everyone. I was just going by the diagram while laying on the floor with a flash lite in my mouth and it says 7.5 amp. I am leaving the 10 amp alone. 😃 Thanks, Nan 1 Link to comment Share on other sites More sharing options...
