Patriot Posted July 2, 2020 Posted July 2, 2020 (edited) I was just researching solar tax credits and learned that it appears this may apply to our new 2020 Oliver. We will forward this info to our CPA and see how it shakes out. Open source google info- 2020: Owners of new residential and commercial solar can deduct 26 percent of the cost of the system from their taxes. 2021: Owners of new residential and commercial solar can deduct 22 percent of the cost of the system from their taxes. Does the solar tax credit apply to RVS? This program applies to all 'dwelling units' including houses, mobile homes and boats, and the current solar tax credit is valid for any RV that has been accepted by the IRS as a second home for tax purposes. ... The credit has been extended to the end of 2019, but scales back then disappears by the end of 2021. Edited July 2, 2020 by Patriot 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
Overland Posted July 2, 2020 Posted July 2, 2020 (edited) Yes, we had no problem taking the credit on ours. You can also take the credit for other solar related items that you purchase at the same time, like battery upgrades, inverter, etc. It can be a significant credit if you're considering the new lithium upgrade. Edited July 2, 2020 by Overland 2
Patriot Posted July 2, 2020 Author Posted July 2, 2020 15 minutes ago, Overland said: Yes, we had no problem taking the credit on ours. You can also take the credit for other solar related items that you purchase at the same time, like battery upgrades, inverter, etc. It can be a significant credit if you're considering the new lithium upgrade. Thanks Overland, we will have our accountant sharpen her pencil. 🧐 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
Moderators SeaDawg Posted July 2, 2020 Moderators Posted July 2, 2020 I'll add this caveat, but check with your own cpa. We were told that you could only take the credit on one "home" on a year. So, if you're adding solar to your sticks and bricks home in the same year, don't count on a credit for the trailer. Otherwise, second home. Bathroom and sleeping facilities. Sticks and bricks, trailer, motorhome, boat. 1 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good.
Patriot Posted July 2, 2020 Author Posted July 2, 2020 1 minute ago, SeaDawg said: I'll add this caveat, but check with your own cpa. We were told that you could only take the credit on one "home" on a year. So, if you're adding solar to your sticks and bricks home in the same year, don't count on a credit for the trailer. Otherwise, second home. Bathroom and sleeping facilities. Sticks and bricks, trailer, motorhome, boat. We are set. Yes, naturally check with your CPA. 👍🏻 1 2020 OLEII - Hull #634 aka- “XPLOR” TV 2021 F350 6.7 liter Diesel Lariat Ultimate Tremor aka - “Beast of Burden” Retro upgrades - Truma Aventa 13.5 AC, Alcan 5 leaf pack, Alcan HD shackles & HD wet bolts, 5200lb never lube axles. XPEL 10 mil PPF front both front corners, 30 lb LP tanks, Sea Biscuit Front Cargo Storage box. North Carolina 🇺🇸
