Jairon Posted November 25, 2020 Share Posted November 25, 2020 The Oliver measurements documentation states that the height of the propane container is 31 inches, does anyone know if these fit? https://www.vikingcylinders.com/shop/lifestyle/31-lb-vapor/ The height is 28.3 inches and an inch or so would be needed for the mount. I found a re-certification shop near me so they are kind of tempting... If not, is anyone running 30lbs aluminum tanks? 2019 Toyota Land Cruiser 2021 Oliver Elite II, Hull #748 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted November 26, 2020 Moderators Share Posted November 26, 2020 We have fiberglass lp tanks on the boat. Bought them for dual use in the trailer, but we found it can be hard to get fiberglass tanks refilled. Erring on the side of caution, refillers have refused us in several places outside of marine areas. We use 20 lb standard steel tanks in the trailer. They're easier to lift in and out. You can always carry a third, in a crate to keep it upright, in the truck bed if you think you'll need it. They're easy to get refilled, or swap out if necessary. I do know that a number of people carry 30 lb tanks. Hopefully, they'll see your post. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Link to comment Share on other sites More sharing options...
Jairon Posted November 26, 2020 Author Share Posted November 26, 2020 (edited) 1 hour ago, SeaDawg said: but we found it can be hard to get fiberglass tanks refilled. Thanks for the info. The Lite Cylinder Co. recall was over 7 years ago so I was hopeful the general consensus had changed. I'll probably still give them a try in 22 or 31 lbs size depending on the fit. If nobody has attempted the 31 lbs tank or done the measurement, I'll update the thread with what I find out post delivery date. Edited November 26, 2020 by Jairon 2019 Toyota Land Cruiser 2021 Oliver Elite II, Hull #748 Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted November 26, 2020 Moderators Share Posted November 26, 2020 9 hours ago, Jairon said: Thanks for the info. The Lite Cylinder Co. recall was over 7 years ago so I was hopeful the general consensus had changed. I'll probably still give them a try in 22 or 31 lbs size depending on the fit. If nobody has attempted the 31 lbs tank or done the measurement, I'll update the thread with what I find out post delivery date. And, it may have changed. We haven't taken ours on the road in a number if years. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Link to comment Share on other sites More sharing options...
DavidS Posted November 26, 2020 Share Posted November 26, 2020 According to this post from @Cobra1169, the Viking tanks should fit. Also, another post. 1 David Stillman, Salt Lake City, Utah 2016 Oliver Elite II Hull 164 | 2017 Audi Q7 tow vehicle. Travel and Photography Blog: http://davidstravels.net Link to comment Share on other sites More sharing options...
Jairon Posted November 27, 2020 Author Share Posted November 27, 2020 Thanks, David. Cobra's post introduced me to composite tanks. I didn't know they were a thing before he took pictures of his setup. I was hopeful someone was brave enough to try the 31 lbs tanks but it looks like I'll need to do the measurements myself. 2019 Toyota Land Cruiser 2021 Oliver Elite II, Hull #748 Link to comment Share on other sites More sharing options...
