Huh. My countertop — the cubby hole slot area just under the convection microwave — is not exactly, uh, horizontally placed. Not sure why. Nothing to do about it, really. I notice it. Maybe no one else would. Or would even care. Anyway, there is a gap that is wider on the left. It narrows slowly as you look across from left to right. And then it is almost closed (no gap at all) over at the far right. Meh.
2021 Elite 1 -- Hull #731
Ram 1500 Rebel 4x4
Now Sold
That countertop should just be held on with Velcro (it is on our Elite II).  You can pull it up and try to reposition it.
Edited by FrankC
Just now, FrankC said:
That countertop should just be held on with Velcro.  You can pull it up and try to reposition it.
Thanks! I will look for the velcro. I have not seen it yet. This is the 2021 Elite 1.
Ram 1500 Rebel 4x4
Now Sold
Or it might not be the countertop.  Looking closer at your photo, the countertop looks straight with the bottom of the microwave, so maybe it is the cubby that is misaligned.
It appears to be all one big molded piece with nothing to “move.”
Ram 1500 Rebel 4x4
Now Sold
I just lifted up on my "countertop" and it came off, held on by Velcro. Opens up possibilities. I wanted to make some changes/additions to the countertop. I have a leak around the sink to fix. And wanted to put an extension off the end, next to the rangetop. There is essentially no countertop as is.
I have a different refrigerator than you, I think. I don't have the cubby below the countertop.
My countertop was lifte in the front a bit. When I replaced it, I smushed it down, and it is no longer lifted.
2022 Ford F150 4x4
2021 Elite I #758
      Map of Provinces I Visited
I'm guessing that the difference here in the countertops is that one has Fibergranite and Moonlight's does not have fibergranite.  If there is no fibergranite then there is nothing held on by Velcro.
I lifted the countertop off and there are two thin velcro strips. I tried to get it back on so the slant-gap wasn’t showing any longer. No luck. Will live with it. Thanks all.
Ram 1500 Rebel 4x4
Now Sold
Something is not right with the installation there.  The countertop lines up with the bottom of the microwave as it should, but does not line up with the refrigerator cavity and cubby.  I am speculating here, but it looks like the horizontal cubby above the refrigerator is integral to the frame surrounding the refrigerator.  Perhaps this "frame" is inserted into the molded fiberglass casework and was installed improperly.  Is the horizontal bottom face of your refrigerator parallel with the floor?  If not, then that is where the problem lies.
Materials and workmanship should be covered under your warranty.  I recommend that you open a service ticket on this (send photo) and see where it goes.  They may have you take it to somewhere near you for a fix rather than a trip back to Hohenwald.
At any rate Oliver needs to know of this issue so that it can be corrected.  I am picking up an Elite l in June and I have a whole list of issues that I have learned of on this forum that I need to check before accepting delivery.
I know from following you on the forum that you have had some real frustrations, especially traumatic because now this is your full-time home.  I hope that you have not had regrets.  My research indicates that Oliver has far fewer QC issues than the other guys.  Take a look sometime at the owner forums of Olivers chief competition.  I was on there just the other day attempting to find out how much suspension to frame clearance they have.  Couldn't find it.  What I did find was page after page of problems and complaints.  It's like that is all they talk about.
Mike and Yasuko
2021 Legacy Elite Hull #820
