While adjusting the fan in the middle of the night a metal part broke off in the fan and flung pieces around. Now the fan will not shut off unless I pull the fuse. Has anyone seen this part break before?  It is metal.  I'm sure it's not replaceable after 5 years.
Thoughts?
Maybe I can contact MaxFan and see if they have a spare part.
Chris
2016 Legacy Elite II  o-o  Hull #110  o-o  "Rock'in 110"  o-o  Twin Bed (sometimes converted) o-o 5-leaf Alcan Springs (installed Feb 2026)
2020 RAM 1500 Limited 5.7L
Augusta, Georgia
Maxxfan should have that part. If you don't have a manual with a parts list, you can Google it. ( I used maxx fan parts explosion. Came right up.) Finding the part number will help, before you call or do a Google search for a secondary vendor.
Back in the day, (sigh) FanTastic would have sent the part for free. Dometic bought them. Maxxfan is airxcel, so quite possibly easier to obtain parts than Dometic.
Good luck, and let us know how it works out.
Mine broke as well after about 5 years of use.  I detailed the issue with pictures HERE.  I was able to order the part and do the replacement. You don’t have to remove the entire fan to do it, just the cover and the arm.  I removed the whole thing and did a thorough cleaning too.
Do a search on Maxxfan and you’ll find other threads.  Mike
If you ever needed parts that is... Our 2005-ish Fantastic fan in our Ford E250 is still going strong. Manual open/close, three speeds, bi-directional, and super simple. No remote, no temperature or rain sensor - seemingly much harder to fry with condensation than these fancier fans and the raise/lower mechanism seems pretty darn solid. The lid has gotten a bit stuck closed at times an we've opened it with a little extra torque on the crank and so far haven't trashed it. Imagine that - a component designed and built to last LONG after the warranty expires, like our trailer frames and shells...
Oliver Elite II hull #709
Yeah, I finally got on the roof to see what was what. I'll order the new part today. For now, a temporary prop will do. I'm full-timing for now, so I need the fan going.
Thank you everyone for the details.
Chris
Augusta, Georgia
