I've been through the winterization YouTube video at least a dozen times and so far I've only been able to get any anti-freeze into kitchen sink via cold water. I never get any pink via kitchen hot water and nothing at all through the bathroom sink or the outside shower. I thought perhaps the faucets were aerating the water in such a way that it was not apparent that anti-freeze was coming in so I captured the water into a cup to look for color and still nothing.
I get almost no pressure to the faucets even if I let the pump run for well over 2 minutes.
Thoughts?
Are you sure that the hot water bypass valve is turned so that the handle faces the rear of the trailer?  The bypass valve is featured beginning about 1 minute into the winterization video.
.... (now this is an example of the blind attempting to lead the blind 😉)
2021 Oliver LE2
Ram 2500 diesel
Yes, sir. I actually never changed it back after sterlizing the system a couple of days ago.
RE-check that hot water bypass just to make sure.
OK - turn off the kitchen faucet and open the bath faucet.  Any luck?
If no luck then look at the level of antifreeze - is it going down?  If its going down then the stuff is going somewhere.  If its not going down then there must be a block somewhere between the kitchen and the bath.
That's the interesting part. It went down to about half of the jug and that's when I got the cold water winterized in the kitchen. Nothing else has moved the line in the jug. I'm rather flummoxed. I'm considering just taking the trailer to low-elevation NV for the winter(It's not far...lol).
This is probably a dumb question (and no offense intended), but are you sure that the filler hose extended into the bottom portion of that antifreeze jug?
2021 Oliver LE2
Ram 2500 diesel
Ha ha! No dumb questions. For sure. It's one of the first things I looked at when I wasn't getting the expected results.
You know what I didn't check though? If the hose or the filter on the inlet port somehow clogged after getting enough fluid to flush the cold in the kitchen. I will have to check that when I get back out there today. I can't imagine how it could have since the hose is quite short and was inserted directly into a fresh A/F bottle but...
  • 3 weeks later...
I'm having the same problem.  I've check everything mentioned above.  The level of antifreeze in the jug never goes down.  I remember having this problem last year and I solved it by raising the AF jug onto the bumper.  This is not working this time.  Even when I raise it as high as the 3 foot hose allows.
Interesting...I wondered about the length of the house/strength of the pump so I shortened my hose a bit and then put the jug on the bumper. Haven't made a difference for me either. I guess I'll call Oliver service this week to see if they have any ideas.
I had a similar issue. My problem was the fittings on the hose I was using was not air tight and causing a pump priming issue...intermittent or none at all. I resolved it by using a new hose with a "factory crimp" and some telfon tape. Once I did this the anti-freeze flowed to all faucets within a few seconds. There was no question when the water changed from clear to pink.
