Designing some modifications to my storage building for my future (September 22) Elite II and I seek some measurements. I thought I had previously seen a diagram on the website that included them, but can not find again. I need the measurement from the hitch end to centerline of the front axle and from the back bumper to the centerline of the back axle. Can someone please either direct me to the location of the required Oliver diagram or provide the measurements?
Thanks
Door County, WI
This is just an unabashed "bump," since I can't answer your question.
Good luck.
I just went out and measured.  I just layed the tape measure at a point as close as I could to the back bumper, then did the same for the hitch.  More exact would have been to crawl under the trailer with the tape measure attached to either the hitch or bumper but I’m not crawling under the trailer tonight!  I don’t know if Oliver has these measurements on their web page anywhere.
79” back bumper to rear axle centerline, +/- an inch or so.
168” end of hitch to front axle centerline, +/- an inch or so.
Mike
78.5"  and 171" on mine, just eyeballing in the dark.
Our eyeballs are pretty close….
  • Haha 2
