I read through this thread on Airforums this morning about the dangers of overfilling of propane tanks.  I usually get mine filled locally at a propane supply place, it’s all they do.  Something to be aware of, the fire danger is real!  Does anyone have experience with this?  Here is a quote from one of the posts:
“This is correct, DO NOT use any propane until you open the 80% bleeder screw on the valve of the tank and vent in an open area / safe place until only vapor comes out instead of liquid LP.
It is possible to have liquid LP go through the regulator and to the appliance and cause a BIG FIRE!!!
I had a tank overfilled once like you, I hooked it up to a BBQ to burn off the extra LP. The flames were over ten feet high! I turned off the LP and the flames continued for ten minutes with just was in the hose!!!
DON'T DO IT.............!!!!!!”
  • Wow 3
If a modern tank is functioning correctly it can not be overfilled. Modern tanks have a internal shutoff valve that only allows a specific liquid level. Of course there is always the possibility that it is not functioning correctly.
2021 Oliver Legacy Elite II Hull #845
I would like to see a video of that. Yes, it is prudent to watch the person filling your tanks! Thanks for posting.
