How do I enter my tow vehicle and trailer type to be on this message at the bottom??   Thanks.  Mike
2015 Dodge Ram 1500.  2021 Elite ll Standard. Hull #905
Any information that is added to your signature will show up at the bottom of each post.
I’m struggling.  I’ve filled out all info in my Profile.  Is that different from Signature?.  Sorry for my lack of knowledge.  Mike
Click on your name in the top right corner.
Another window will open, click on Account Settings.
When a new window opens, click on Signature on the left side.
Edit the signature section with the information you would like to appear at the bottom of your post’s and click Save.
Good luck,
On my phone, it's several steps to get to signature.
I go to the three bars/"hamburger" button, top right. From the drop down, select account, then account settings, then settings area, then signature.
It's quite the treasure hunt to find it.
Alright Thanks to Mike and SeaDawg they lead me forward and it made it thru my thick head.  Thanks guys.  Mike
Would you mind if I edited the title to something like add info to signature? This comes up a lot,,and it's definitely not intuitive.  Takes a bunch to get there.. glad you did.
Might help others
  • The title was changed to How to add info in signature
  • The topic was pinned
  • 5 months later...
Hi all. I’m new to the site and was also having difficulty adding my TV and Oliver trailer info into the signature page, or even finding the signature page for that matter. I was attempting to make changes using my iPhone and simply could not find the screens called out in the instruction for updating the signature page. I finally ended up using my iPad and “SURPRISE” everything appeared on my screen. So, if you’re having difficulty you might consider logging in via a different device. It sure worked for me!
Jeff
2014 Ford F350 Super Duty 6.7 Power Stroke with heavy duty tow package; 3.55 ratio; AirLift rear suspension
2023 Elite ll Twin Bed and Lithium Pro and Truma Package; Hull #1368; Delivery Date: April 12,2023
Homebased in Richland, WA
  • 1 year later...
