If you don’t want Dish or Direct TV is the device good for anything? Can it be altered for local TV? Has anyone removed a G2? Every time #266 is plugged in the G2 is frantically trying to phone home.
I don’t understand your last sentence…..It’s a directional satellite dish shaped TV antenna, that is all it can do. Has it ever worked correctly? Has it been setup properly? Does it have a clear view of the sky, no trees? Is the trailer level? Sure it can be removed, but it is going to leave some holes that will have to be sealed properly. You could put a regular tv antenna or a cellular antenna in that location, but getting the new cables run to the rear of the cabin will be a challenge. I personally would just disconnect the G2 inside and leave the antenna in place for a future owner to never use 😬 …. I don’t understood why Oliver chose to put it in the roof, the current sat antenna option is portable with a tripod, so you can position it where it will see the sky properly. I guess they finally figured out that a fixed roof mount on a travel trailer was just silly…..
It’s only good for satellite TV.  Nothing else.
A huge Kingdome gen 1 came with our 2008. It was pretty much useless. (Rarely camp with 110, didn't have dish service after a few months. And never worked well, anyway.)
We had a switch to turn it off, plus it plugged into an outlet in the attic. We unplugged it. (Otherwise, as you noted, it would try to scan for signal, and make crazy noises, if we were plugged in.)
We removed the old nonfunctional dome several years ago, as it was old and the dome had a few cracks. And, it was just a waste of space.  Taped over the wires and flat mounting brackets  with eternabond, so we could (ostensibly) get in and pull the wires  through to run a TV  antenna wire, someday,  if we wanted to. We were pleasantly surprised that there was just a small hole for the wire run,  when I downloaded the install manual...
Watching TV isn't our gig, so, no urgency. If the same is true for you, and nothing is leaking,  follow John's advice, and disconnect it, or just remove it, as we did,  if you feel like getting on a ladder, and are in the mood. We were working on other things at the time, so seemed like a good time to clean up the roof.
