Mountainman198 Posted July 24, 2022 Share Posted July 24, 2022 I don’t like to cook in my Ollie and usually cook with a Wok when not grilling. When there is electric (like many of you) I use my portable induction cooktop. When there is no electric, I have been using a small, single burner high pressure burner. It is not very hot and does not like wind. The search for a high output, single burner propane burner that I can use with the Ollies low pressure quick connects yielded several units, all bulky or heavy. Plus most were North of $150. I am a fan of .50 cal ammo cans as they are durable and compact and a clean-stow in the pickup bed. Also simple to label with a sharpie since I had already built a self-contained, low pressure firepit from a ammo can, I decided to look for components to build a high output single burner version for cooking The 50,000 btu burner came from a local home goods store (Menards), the propane orifice and valve from the local propane supplier, the burner grate from salvage and the ammo can from JAX outdoor store. All-in the unit cost $40. Haven’t tested it yet but I dont see why it wont work well Here is the final product. 2 1 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW Link to comment Share on other sites More sharing options...
John E Davies Posted July 24, 2022 Share Posted July 24, 2022 That is great, thanks for posting. I love those mil surplus cans. I have all my towing paraphernalia in one of the ubiquitous .50 cal version….it fits neatly in a plastic milk crate, and if I leave the top latch undone, the lid will open and close while it is in the crate. The only problem with your setup is your ammo will “cook off”…. 😬 For those who may not know: … https://www.armyandoutdoors.com/blogs/news/an-introduction-to-ammo-cans Why did you pick such a huge size? A typical home gas range big burner is less than 20,000 btu. John Davies Spokane WA SOLD 07/23 "Mouse": 2017 Legacy Elite II Two Beds, Hull Number 218, See my HOW TO threads: https://olivertraveltrailers.com/topic/john-e-davies-how-to-threads-and-tech-articles-links/ Tow Vehicle: 2013 Land Cruiser 200, 32” LT tires, airbags, Safari snorkel, Maggiolina Grand Tour 360 Carbon RTT. Link to comment Share on other sites More sharing options...
Moderators SeaDawg Posted July 24, 2022 Moderators Share Posted July 24, 2022 I could see doing a low country boil on a big pot on that burner. My turkey fryer burner has a ton of btu, but I would be hesitant to put a big pot of oil on the ammo box. Its a great idea, and if the burner is easily adjustable, it should work in wind. 2008 Ram 1500 4 × 4 2008 Oliver Elite, Hull #12 Florida and Western North Carolina, or wherever the truck goes.... 400 watts solar. DC compressor fridge. No inverter. 2 x 105 ah agm batteries . Life is good. Link to comment Share on other sites More sharing options...
Mountainman198 Posted July 24, 2022 Author Share Posted July 24, 2022 4 hours ago, John E Davies said: That is great, thanks for posting. I love those mil surplus cans. I have all my towing paraphernalia in one of the ubiquitous .50 cal version….it fits neatly in a plastic milk crate, and if I leave the top latch undone, the lid will open and close while it is in the crate. The only problem with your setup is your ammo will “cook off”…. 😬 For those who may not know: … https://www.armyandoutdoors.com/blogs/news/an-introduction-to-ammo-cans Why did you pick such a huge size? A typical home gas range big burner is less than 20,000 btu. John Davies Spokane WA the burner was what I found locally and it was cheap. Figured I would try it and see how it works. If it is too much of a afterburner I can always downgrade later. 3 2021 Elite II, Hull# 898 2018 Toyota Tundra, 2003 Dodge Ram 3500 5.9l SRW Link to comment Share on other sites More sharing options...
