Jheim Posted September 16, 2022 Posted September 16, 2022 Hi does anyone have any suggestions on what the best way would be to remove old caulk on my 2021 Oliver LE 1? Also any suggestions on what type of cualk to use? Thank you
Moderators Mike and Carol Posted September 16, 2022 Moderators Posted September 16, 2022 Is there an issue with the caulking around your windows? If it is a 2021 I wouldn’t think that the caulk would be old. Any leaks? Our 2016 Oliver is going on 7 years old and the caulk around the windows is original, no leaks, no issues. Mike 4 Texas Hill Country | 2016 Elite II #135 | 2020 Ram 2500 6.7L Cummins
Jheim Posted September 16, 2022 Author Posted September 16, 2022 The larger window at the dinette table on my Oliver le1 leaked recently when it rained really hard. I see some of the caulking on the roof or around the window could be the problem. I'm thinking if I just replace whatever looks questionable should hopefully fix the problem. 3
Hokieman Posted September 16, 2022 Posted September 16, 2022 11 hours ago, Jheim said: Hi does anyone have any suggestions on what the best way would be to remove old caulk on my 2021 Oliver LE 1? Oliver has a few videos on this topic including caulk recommendations in the Knowledge Base. Check to be sure the problem is not just clogged window tracks. 6 “Ramble” - 2021 Legacy Elite II #797; 2020 Ford F-250. Former owner of 2019 Oliver Legacy Elite #431. Blairsville, GA
Roger P Posted September 16, 2022 Posted September 16, 2022 Plastic scaper and clean with minerals spirits, swap and dry and apply new calking…. 2 Elite2 2022, #1120. RAM 3500 Laramie 2022 diesel SRW Quebec, Canada previous rig: 35 foot fifth wheel with Ford f350 2018 diesel DRW
dewdev Posted September 16, 2022 Posted September 16, 2022 Before removing the caulking, I would suggest that you check the drain holes at the bottom of the window track to make sure they are clear and allowing the water that hits the window glass to drain out of the window track. 3 2018 Oliver Elite II, Twin Bed, Hull #354, new 3- 130 Lithonics batteries and Xantrex Freedom XC 3000 Pro Inverter in 2025 2024 RAM 1500, 4 x 4; Gas. 5.7L V8 Hemi MDS VVT Torque; 3.21 rear axle ratio w/TIMBREN spring rear suspension addition Maine
Jheim Posted September 16, 2022 Author Posted September 16, 2022 1 hour ago, Roger P said: Plastic scaper and clean with minerals spirits, swap and dry and apply new calking…. So mineral spirits won't hurt the gel coat?
Jheim Posted September 16, 2022 Author Posted September 16, 2022 17 minutes ago, dewdev said: Before removing the caulking, I would suggest that you check the drain holes at the bottom of the window track to make sure they are clear and allowing the water that hits the window glass to drain out of the window track. Yes cleaning the window track was the first thing I did. It hasn't rained hard since then but there are some places that the caulking seems a little sketchy. I'm figuring better to be on the safe side and reapply silicone or whatever I'm supposed to use. 3
Roger P Posted September 16, 2022 Posted September 16, 2022 No, minerals spirits doesn’t heurt gel coat, clear coat, paint and fiberglass. Its the only product that doesn’t heurt them. I used them on my previous motorhome and fifth wheel. If your calking is clean, you can apply new one on it….there is a really good youtube channel with a professionnal technician who give really good tricks « AZ Expert ». 1 Elite2 2022, #1120. RAM 3500 Laramie 2022 diesel SRW Quebec, Canada previous rig: 35 foot fifth wheel with Ford f350 2018 diesel DRW
Jheim Posted September 23, 2022 Author Posted September 23, 2022 Thank you Roger and I will definitely look for those YouTube videos
